FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
Where is the best place to mount a pressure gauge on 1991 evinrude 225. One head is hotter than other while running, what could cause that? Will thermostats help mine were removed?
elwilliams13,<br /><br />You can tee into the telltale line.<br /><br />Put the stats back in. They were there for a reason. Running without them causes hot and cold spots in the engine. Your engine will idle alot better too.
if you still have the water control valve you will have to put T into hose feed from starboard side adapter plate to the water control valve.<br />that is the only way to get accurate readngs.
Thank ya, sir, just wanted to make sure I was doin' it right, as thats how we've done it here for quite some time, but this disscusion got me thinking maybe I wasn't getting the reading I needed.....Thanks!
