Run motor out of the water
mstring
Is it possible to run a 115hp johnson out of the water without burning it up?? And if so how long is to long??? Thanks in advance....
D
DJ
Guest
Re: Run motor out of the water
NO!!!<br /><br />One second is too long. The water pump impeller needs water for lubrication.
mstring
Thanks for your quick reply.It only makes sence....
ob
If it ran more than 30 secs you would likely have impeller damage.That's not knowing whether it was bone dry to start with.
wikelam
Boats float on water, outboards go on boats.
jasperpso
what the heck is that supposed to mean? <br /><br />jason
wikelam
OutBoard engines are made to run IN water!!!
jasperpso
ok, i agree with that, but you really didnt go that far in the previous post.. now i understand were you were coming from..
JasonJ
Just run it on muffs, and keep the hose on all the way. You may notice the pee stream may not be as powerfull as when it is in the water, but it should be fine.
