'69 Johnson 55-oil coming out of prop shaft
junlab
can somebody guide me? i see oil coming out of my prop shaft. what do i do?<br />all replies are appreciated
ajp
Re: '69 Johnson 55-oil coming out of prop shaft
It is actually lower unit oil or black sludge/oil. <br /><br />If it is the latter, it is ok. It is oil that is not burned and goes out the exhaust port-prop hub.
junlab
thanks AJP.<br />It could be the unburned oil.<br />Happy counting!
sos
Jun55<br /><br />Drain your lower unit and check the lube in it. If it has changed to a milky colour or if water comes out you have a seal gone in the lower unit.
junlab
Thanks SOS.<br />I'll try draining it this weekend. If seal is gone how do I fix it. Have most of the tools but new to outboard engines.
