Evinrude 115 HP 1991 Fasttrack
G DANE
I have above motor for my 17 runabout. I just read it is a Fasttrack model. What does Fasttrack mean ?? I was told is has a special version T&T, but were there other modifications to this model ??
thosch
Re: Evinrude 115 HP 1991 Fasttrack
I believe this only refers to the type of T/T.
G DANE
thanks t.h. <br /><br />It seems odd to mee - T&T is T&T - isnt it ?
thosch
My '91 90 Johnson has the FastTrak T/T. I think the difference is faster tilt rate and a few more degrees of travel, compared to the standard T/T unit that was offered.
G DANE
Thanks t.h.<br /><br />By the way - the T&T motor cover is rusty as this motor has been operated in salt water - manual says to remove unit before removing motor. Do you know if it is possible to remove just the motor and sand, prime and paint it, to stop the corrosion. Do you know what the compression is on yours - on mine 3 cyls have 122 and the fourth 132 - i have not ran it in water yet.
OBJ
Hi G Dane...<br /><br />The difference is in the angle of TNT. The Fast Tracks have more. More angle in. I believe it's about 6 degrees more angle than the old style. <br /><br />I'll give the book a check tomorrow and let ya' know.
OBJ
OOPS...forgot....usually with the OMC (Bombardier) TNT's, the motor can be removed for maint.
G DANE
Thanks Jim<br /><br />Removing from unit in bracket on boat ( in driveway of coarse ) is possible then ? How does motor axel engage in pump unit ? by splines ?
