1967 20hp johnson
jsmzdlt
i have a 20 hp 1967 johnson and i need to change the impeller and im new to this.is this something i can do or should i take it to someone else and also could this cause my motor to feel like its slipping at times?any help would be greatly appreciated. thank you jeff
plywoody
Re: 1967 20hp johnson
Well, if you have never done it before, and wish to attempt it, get a good manual before starting and read thru it first before you take it apart, to make sure you are comfortable that it is something you think you can handle. It is not terribly difficult, but you have to make sure you do it right, and there are little things, like seating the water line, that have to be done just right for it to work. If you are not comfortable tackling this, by all means take it to a competent shop.<br />And what do you mean by "slipping"?
jsmzdlt
by slipping i mean it is like being in a staight gear car and riding the clutch it will go but it is hesitant. thanks jeff
rickdb1boat
Odds are you have a spun prop, causing the "Slipping". Take it to a Prop shop and have it checked out..
plywoody
The two are separate issues, of course. The water pump impeller pumps water to cool the engine. It has nothing to do with the drive mechanism, so to answer your first question, no the water pump impeller will have nothing to do with this "slipping"
