FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
Mary ,Post hp of motor ,if known ,and what numbers you do have and someone will assist.The model number is usually required.Look on motors transom bracket and also on engine blocks silver welsh plug for additional numbers.
That is not a Johnson model number.<br />...and your from what you wrote in your profile.<br />If it isn't a joke and you have a model number you'll find the year here:<br /> http://www.marinshopen.se/guide/guide.htm <br /><br />If you find the model number (not the serial number) and still can't find out the year, post it here and someone will tell you.<br /><br />If you don't have a model number, describe the colour and propeller; number of blades, exhaust thru prop or above the prop. Can you post a picture of it?
No not really. I just want to make sure it is a 6 hp Johnson. I think you narrowed it down a bit.<br /><br />So you can't find the model number? It should be where you found the serial number. Also look under the cowling, on the powerhead, for a quarter sized aluminium plug for the model number.<br />Possible model numbers: <br />1965 CD-CDL-22 <br />1966 CD-CDL-23 <br />1967 CD-CDL-24 <br />1968 CD-CDL-25 <br />1969 6R69-6RL69 <br />1970 6R70-6RL70 <br />1971 6R71-6RL71 <br />1972 6R72-6RL72 <br />1973 6R73-6RL73 <br />and so on...<br />The "L" is for long shaft. You'll se either<br />like CD-25 or CDL-25, 6R69 or 6RL69 and so on.<br />I have a 1965 short shaft, CD-22.<br /><br />I hope you find the number
