Re: 1979 15 hp johnson
Hi rareheir<br /> What color is this oil? Is it clean and clear, looks like honey? Or is it black and nasty, dirty with a little crud? Do as OB suggests and change you gear oil. If it looks ok and there is no water in it, you probably just have exhaust oil dripping out. No big deal. Its also a real good Idea to remove the prop and inspect the prop shaft for fishing line or other derbis that may be wraped around the shaft. Don't forget to greese the prop shaft with anti corrosion greese before installing the prop. Clean oil= problem. black and nasty = OK.
