prop question
sterling66
Its me again,Just bought 7.5 evinrude ,prop has a few small dings.Wondering what to do ,if anything. Also can someone tell me wher i can see props for this oneline.Props on this site are much to big unless i cant find them? And thank you! Hooty. :D
ob
Re: prop question
Sterling , what year is your 7.5 rude
sterling66
Re: prop question
Thank you dont you guys sleep in texas, second fellow to help me tonight. Thank you. I live on the west coat of bc there hours or more time diff.
sterling66
Re: prop question
I have a 71 rude 9.5 would props be the same? Also<br />what about small nicks in prop is this hard on shaft?
rickdb1boat
Re: prop question
Just take a file and clean them up, if they are'nt to deep!<br /><br />Edit: Nope, the 9.5 Prop won't work. Sorry!
rickdb1boat
Re: prop question
A little info on the 7.5 Prop:<br /><br /> Propeller Type: Outboard<br /> Manufacturer : EVINRUDE, JOHNSON<br /> HP / Model : 7.5 HP<br /> Year : 1980-PRESENT<br /> Boat Size : STANDARD REPLACEMENT<br /> Material : ALUMINUM<br /><br />Blades Diameter & Pitch Rotation Part number Style Comments <br />3Blade 8-1/2Dia. X 9" Pitch RH 012032 MICHIGAN MATCH <br />--------------------------------------------------<br /><br />Propeller Type: Outboard<br /> Manufacturer : EVINRUDE, JOHNSON<br /> HP / Model : 7.5 HP<br /> Year : 1980-PRESENT<br /> Boat Size : HEAVY BOATS<br /> Material : ALUMINUM<br /><br />Blades Diameter & Pitch Rotation Part number Style Comments <br />3Blade 8-1/2"dia. X 7"Pitch RH 012031 MICHIGAN MATCH
