won't keep running , now what ???
gerke
my old 1965 6hp johnson has got some problems lately .<br />at first it ran great , but when the engine was hot it would not restart , i had to wait for about 5 minutes and then it started .<br />but today i went out and it started , but bogged down immediately , and would not restart for a while , and when it finaly did it bogged down again and again .<br />when it bogs down fuel is comming out of the carb , and it looks like the engine is flooding .<br />i checked the spark plugs the upper was black .<br />and i have another question what is suppose to go through the hose that is placed vertical on the side of the powerhead , i see fuel going through is that good ??
Joe Reeves
Re: won't keep running , now what ???
Gerke.... It's time to remove, clean, and rebuild the carburetor on that engine. The vertical line you ask about is a main bearing lubrication feed line.
gerke
thanks joe<br /><br />but that vertical line filling whit gasoline is that ok , and i forgot to mention that the engine creates a lot of white smoke , even under the cover .
Bob_VT
Is the motor overheating? AND I really am not sure fo I will leave this comment to the experts but what oil/gas ratio are you running? I would also check the qaulity of the gas.<br /><br />Joe Reeves....back to you!<br /><br />Bob
gerke
hi bob<br /><br />i'm running on a mixture of 1:50 , i think that's what they reccommend .<br />the gas is brandnew , so i think that's ok .<br />and about the engine overheating i think it's not even warmed up when this happens .<br />oh and i think the smoke under the cover comes out of the carburator .
Hooty
Hooty concurs with Joe Reeves. Either needles and seats are leaking,floats are out of adjustment or all the above.<br /><br />c/6<br /><br />Hooty
gerke
i took the carb off and cleaned it up and put it together again . and yesterday i gave it a try .<br />but there was no change , so i took the carb off and had a look at what we (in holland ) call the membramen ,wich i had done earlier this week but it seemed ok at the time . but what i saw now whas a metal o ring stuck between one of the membramen , the o ring came off the lean rich knob i put it there myself whit a spring to stop the knob from turning from vibrations of the engine , anyway i took the o ring out and put the carb on , and it runs like a champ again .<br /><br />thanks for al the help you gave .
