Finding a newer 4 stroke motor for my old 13' Whaler
Peggylaugh
OK - Who knows how to solve this dilemma? In the Lake Tahoe area all boats are required to have 4 stroke engines, so my 2 stroke 35 HP evinrude will no longer be legal on my 13' Boston Whaler sport - a 60's model with a 15" transom.<br /><br />I have been searching for a decent 30-40 HP 4 stroke motor with power tilt and trim that will fit the short transom and no one seems to make one anymore. I have been advised to either forego the power tilt/trim and get a yamaha or mercury with the short shaft, or have my transom built up with a 5 inch piece of metal or wood that would bolt onto my back end. I don't like the idea of making my whaler look jerryrigged and take away from it's value. Does anyone know where to find a motor with the specs to fit onto my boat? Or do you think that modifying my boat would be the better alternative?
suzukidave
Re: Finding a newer 4 stroke motor for my old 13' Whaler
Not to quibble, but aren't you over the max horsepower rating on that boat with that hp? I know someone with a 40 hp 2 stroke on a BW13 and I believe it's over the rated horsepower (and looks it). <br /><br />If I'm wrong then I'd say try hard to get power trim because the weight of a 35 or 40hp 4 stroke on the back is going to give you trim issues (I know that a 40hp Merc 2 stroke does). You can buy an after market power trim unit from Clarkes. They run about $500, but they work well and will also set you back 4 or 5 inches off the transom which will probably improve your trim and performance. I'd do this before I raised the transom 5 ".
D
DJ
Guest
PL,<br /><br />CMC also make a power trim/tilt for smaller engines. One model up to 35 hp. and another for 35 hp. and up. They will also set back the engine 4-5 inches.<br /><br />They're available through Cabelas.<br /><br /> www.cabelas.com
JB
Howdy, PL.<br /><br />Your boat is rated for up to 40hp.<br /><br />I think Tohatsu makes a 15" 4 stroke engine in the 25 to 40hp range. I could be wrong.<br /><br />If I were repowering a 13 I would put a jack plate on it and use one of the easy-to-find 25 to 40hp used Yammy or Honda engines.<br /><br />OR! I would find out if the 13 can handle the weight of the Suzi DF40. 240lb would be a lot for that hull.<br /><br />Good luck. :)
steelespike
PL, Im dont know that much about about 4strokes<br /> except some are comprimise motors made from existing 4 strokes.I assume they give comprimise<br />performance.<br /> Unfortunately I dont know who builds best or lightest.<br />I do know there are a few 4 strokes(individual models) that are actually lighter than some 2 strokes. I believe Suzuki makes motors for E/J<br /> And I believe Tohatsu is built by another company.<br /> Not much help but Im going to have a look around if I find some info Ill get back.<br /> Take your time and have a good look around.
rlsc98
I have a 40hp merc on the back of my 74'13ft whaler. does a real nice job. The model # 40ELPTO<br />which means ,electric start,power trim,remote steer and controls.
JB
Steelspike. <br /><br />What is a compromise engine? <br /><br />Suzuki does make Johnson's 4 strokes and did make Evinrude 4 strokes.<br /><br />Tohatsu has been making outboards since the 50s. They make the ones sold as Nisssan.<br /><br />risc.<br /><br />Is that a 4 stroke Merc 40? PL is looking for a 4 stroke.
enn
Suzuki makes a 30 hp short shaft 4 stroke with power trim.
