stueywatson
Thread starter- Joined
- Jun 10, 2002
- 13
I'ld better lay it out in order........<br /><br />Shot my mouth off about "A good idea to rebuild something old for reliability and working knowledge"<br />A friend called my bluff and gave me this motor.<br />(He had bought it "sight unseen" and, horrified at it's sheer size, relagated it to the shed without even testing it.)<br />The catch for me was the two thousand Kilometer trip with a trailer (Australian Roads!)to pick it up.<br />Having opened my big mouth and thrown $600 of petrol money at the project I'm pretty determined for some sort of outcome.<br />So. <br />It's and Evinrude starflight V4 #50523 (1960)<br />Initial inspection revealed that one of the sparkplugs (lower port side)was just "sitting in" with the remains of a helicoil. The upper port cylinder also had had a helicoil inserted but it was tight. The lower sparkplug hole was just too big for a helicoil.<br />So I removed the head and had an insert with a new thread put in.<br />I didn't pay much heed to the head as I was eager to see if the thing ran so put it strait back on.<br />The motor started relatively easily and ran for a couple of good bursts.<br />However no water was getting pumped through the cooling system.<br />I replaced a totally missing seal on the top of the impeller housing.<br />This time, after the motor had run for about 30 seconds ( it was pumping water now)it died and there was a strange watery gurgling sort of sound coming from the throat of the carbys, strange enough to promt me to remove the spark plug on the lower port side cylinder and out came a bunch of water. There was also signs of water on the upper portside sparkplug.<br />Removal of the portside head revealed some previously unnoticed irregularities, enough, I hoped, to explain the water. I ground both the head and the top of the cylinders flat and clean and with sealant added reasembled.<br />No change to the situation at all!<br />With the piston (Lower port) up the top I could apply water preasure to the head jacket and there was no sign of water in the cylinder but as soon as the piston goes back past the ports a flood of water comes in.<br />My questions.<br />Are there any gaskets or anything in the manifold or sump between them and the water jacket?<br />Do all the cylinders share a common sump?<br />What about carburetta thoats? it looks like one throat serves port and another starboard ?<br />Any more tests I could do to clarify the situation?
