Re: 81 Evinrude 35hp kicks at higher speeds....
vmaxed -- sorry I missed your return post. Sorry also that the carb adjustment didn't solve the problem. If you are hearing a cough or sneeze, as a lot of us refer to it, the engine isn't getting enough fuel (i.e., running lean). If you have two adjustment needles, it's probably the high speed needle you will need to adjust, and the adjustment is counterclockwise to make the mixture richer. You may also have a partially clogged jet (can try to clean by taking the needle all the way out, then carefully inserting a fine wire -- doesn't hurt to spray carb cleaner in there as well.) But without hearing the sound it's making, it is hard to guess on this end what the cause might be. <br /><br />If you get much beyond mixture adjustments, you really need a manual in front of you -- certainly if you are going to get into the gearcase.<br /><br />Hey -- I hope you make some progress....
