flywheel problems
Brento311
Today, my dad and I tried to take the flywheel off of my 1972 Evinrude 9.5. After finally breaking loose the flywheel nut, we put a flywheel puller on the flywheel but it would not budge. I put a good bit of pressure on it, but didn't want to break something so I loosened it up. We tapped on the flywheel and puller but it would just not budge. Is there something I'm forgetting to do? Thanks<br /><br />Brent :confused:
petryshyn
Re: flywheel problems
install the puller GOOD and TIGHT. Get a heavy hammer and give a GOOD hit on the end of the puller shank. (leave the crank nut on a few turns to prevent the flywheel from jumping off..)<br />Do not hit the flywheel!!! :)
Bear
Been there...<br />There are many kinds of flywheel pullers. Only one kind will do the job. I can't explain exactly what it looks like, but it had three bolts that goes to the three treaded holes in the flywheel.<br />I put my 1965 Johnson 6 HP in my car and stoped by my OMC shop and borrowed their flywheel puller. Costs about a big thank you and a smile.<br /><br />Good luck!<br /><br />/Bear
alcan
Hi Brent<br /> Install puller, give it as much presure as you dare, maybe just a little more. Then give it a solid smack with a med. hvy. hammer. tighten your puller a little more, then smack. please note, that these smacks are delibert and aimed. Were not trying to beat the thing. It will come sooner or later.
micbaca
Make sure you don't have the kind of flywheel the unbolts. You won't pull this type off no matter what. It is characterized by about 10 bolts in a circle on top of your flywheel.
freddyray21
they can be a bear, but a good rap on the end with a lot of force usually does it.
tashasdaddy
do not hit the flywheel. hit the center bolt of the puller. are you using this type puller?
Evinrude Boater
Also known as a harmonic balancer puller. You'll probably break a puller bolt before you damage the flywheel
