The picture doesn't show it very well but I did clean up the contact areas in the holder so the fuse has a good clean surface.That inline fuse holder still looks corroded.
Well, that would be the only remaining item. Transom mounted unit.If you still have the original type alternator the over charging can be from the external regulator
What is this black magic of which you speak? This "one wire marine type"?If defective might be able to get one, but can also change over to one wire marine type
Ok, after cleaning every electrical connection, and I mean every one, I'm happy to report the alternator is putting out a little over 15 Vdc and the battery is getting about 13.3 Vdc.
At the battery I am reading 15+ volts.
Will do. Thank you.If the ALT, Regulator and Bat don't have the same ground potential as each other, this can cause an over voltage event. With motor running connect probes at ALT housing and voltage out, than move ground to Reg ground and then to Bat ground, does the voltage change any?
Next thry to find a voltage drop on cables, should only see millivolts if any
Put probes it Bat ground and end or ground cable on the block. Move to Bat Pos and ALT out
If your meter is not auto ranging, start high and go lower to Millivolts
