electric winch
alldodge
In most cases should enough but depends more on weight of boat, trailer and angle
If trailer is roller than no issue, if carpet bunks than need to be deeper but not to deep. If bunks are plastic, than much easier. If ramp is shallow than may not be able to get it deep enough
How much does the boat weigh and what kind of trailer?
redneck joe
lots of variables but should. I looked into this last big boat i had and it was 5k and i think the 2k winch was enough. Remember you are calculating the pulling weight, not a lifting weight.
glass or tin boat? my 18 tin cc is only about 1400 with motor - a glass would be much more.
if bunk trailer, get bunk slicks.
dingbat
When sizing a winch, consider that winches are rated (max capacity) with an empty spool.
As you add wraps, the pull capacity drops and the your effort goes up.
I always go with the largest 2 speed that fits the winch stand. Your shoulder will thank you for it
JimS123
Google the company's web site for the winch you are looking at. The specs should show proper weight and boat length for each product.
airshot
I agree and love my two speed manual winch....but the heading states "electric winch"....so......?
dingbat
Worst yet….the hp input is fixed. You can’t crank harder as the winch fills up.
My boat weighs @ #4,700 unless I have both fuel tanks filled for an offshore trip.
Had an electric winch rated at #4200 of pull. Winch pulled boat well to about 1/3 of the way on the trailer. By the time the boat made it to the winch stand there was nothin left. Had to pull the trailer to level ground to snug up the cable for the trip home.
With that experience under my belt, I would not buy an electric winch rated any less than the weight of the boat.
redneck joe
bunks/rollers/ramp angle?
airshot
I have only witnessed two electric winches in use on boats in all my boating years. I considered moving to electric a few years back due to bad shoulders. Watching others use electric winches, they apoeared pretty slow. One fella had a snag and needed to back up the boat and start again which took forever. I decided on a two speed manual winch. Best chouce I ever made, works great with minimal effort, and fadter than an electric winch even on the slow easy to crank speed. My winch iscrat? D for up to 3500# but my boat weighs less than 1600#. Can winch it up with one finger.
dingbat
32 roller trailer
Ramp angle ~ 8 degrees
The issues isn’t the ramp, it’s the way marine winches are rated.
In my case, I needed ~25’ of cable to get the boat off the trailer but only needed 8’-10’ cable to get it back on. That 15’-18’ of extra cable on the drum cut the capacity in 1/2 before I even connected the boat to the winch.
Not my winch but clearly demonstrates the issue.
dingbat
The other “small print” in winch ratings nobody reads.
To move weight X at Y speed requires Z horse power. To keep costs down it’s common to use a double line pulley system on the retrieval lines to allow the use of a smaller drive motor. The trade off is that you the cut the retrieval speed by 50%.
My Rule winch was direct drive. Took less than 30 seconds to get the boat to the post. The down side was the cost..$$$
redneck joe
so i'm thinking, both on my winch and tongue jack to have the opposite side operable to be able to use my impact wrench. The jack has enough meat on the pin to grind down to like maybe a 3/8" drive the winch would need a different approach as it is flush.
dingbat
The issue with an impact wrench is going to be the rpm.
A 1/2” variable speed drill works well with the “bull dog” jack (lead screw) I use to change the blades on my #1,200 zero turn.
A “geared” jack would take much more HP. Would give your wrists a real good workout. Would need to be a double reduction (2 spd.) winch to be a viable option
