Pre Alpha 1 228 lower unit install
Deep waters
My ignorance is not bliss. I did not put the drive in forward before removing the lower unit. As a result the prop shaft will not engage and I can't align the outdrive shaft to engage.
alldodge
Welcome
If you just dropped the lower half of the drive, then no issue
Move throttle to forward
Rotate shift shaft until the prop locks in Reverse (note Rev not Fwd)
Raise the lower half into upper half
Deep waters
Thank you. I can't get the last 1/4" to marry. Also, while shaking it around to fit, the shift shaft is no longer in reverse. Your thoughts please?
alldodge
The shift foot should be point forward on the upper half and should be held in position mated to the shift shaft on the bell housing
The prop isn't staying lock in rev so the shift shaft is moving. Could put it in position and then use a bungee cord on the prop to keep the prop locked in place
The splines on the lower shift shaft will mate with the upper shift foot, and it might hang on the 2 pieces if they don't align correctly. It can be done but sometimes it just not worth the trouble for me to save the gasket on the upper.
The easiest way I've found to do it is pull the upper, mate the lower with upper and than install drive
Bt Doctur
All Dodge, I think you meant shifting into full fwd at the control box and rotating the lower splined shaft fully clockwise into fwd ,that will lock the prop in a CCW position not reverse
alldodge
I said it the way I did so I didn't need to explain anything about how the dog clutch works
Deep waters
Thank you for the good information. The shift shaft coupler is pointing port. I positioned the shift shaft to match. Does locking the prop in reverse still apply?
alldodge
Shift shaft should point straight forward not to port
If the lower is in forward the prop will lock when prop is rotated counter clockwise
Deep waters
All is well for now. I haven't yet checked the shifting as I need someone at the throttle to help. In the mean time, now that lower and upper are mated, I need to remove and reinstall it. The bolt to hold the zinc fin fell out and rolled under my work bench. It's a good day! I get to practice.
Deep waters
Specifically rust and oil. 1975 Mercruiser Alpha MC1. If you can point me in the right direction I'd appreciate your insight.
Deep waters
I'm sorry. I posted about difficulties with mating my lower unit to the upper. The information you provided was extremely helpful. I am impressed with the depth of your knowledge. It seems that I asked a question or for information unrelated to my initial inquiry which I shouldn't do.
As to your question, when I serviced the lower unit it had very grimy oil with large rust particles/flakes and I'm looking for some information about where the point of intrusion is.
I'm aware that the exhaust manifold is in bad need of replacement and will get that done when I am able. I gotta get this boat as ready, as good as she can be and on the water so that I can take two great grandsons fishing and maaayybe tubing. Time isn't on my side. What time I have left I'd like to spend it on the water with them as much as possible. Again, my apologies Sir, I will get the hang of this forum and be a better member.
Scott06
The drive will need to come off and do a pressure test to determine it. Likely if you have rust the bearings have gotten exposed to water and its not gonna live very long. You can pop the top cap and see as when sitting the parts of the upper like the top bearing are not bathed in oil. If time is off the essence get a SEI replacement drive and bolt it on vs leak testing and tear down.
is this a salt or fresh water boat? when you say the manifold is in bad need of replacement, just understand that water leaking back in through the exhaust is a real easy way to loose an engine.
Deep waters
Thank you Scott, The upper has been tested and holds well. There wasn't any contamination seen in the gear housing. I haven't yet pulled the exhaust manifold but understand that the shutter/flap will need replacing. The bellows have been cleaned and are in good condition, no tears and well fitted. The contamination in the lower was oil, large 1/8-3/16" flakes of rust and a lot of smaller particles. All of it, save the oil, was magnetic. I can understand the oil but the large flakes are baffling. It seems to me the impeller sends the water into and through the engine and out through the exhaust manifold, then through the bellows. Your thoughts please?
Scott06
When you say contamination in the lower was oil ? or do you mean the contamination was in the oil ? Flakes of rust in the oil means moisture and rusted components inside the drive. If it were mine I would disassemble it if rust flakes presented in the gear oil.
If you mean you have oil and rust flakes in the exhaust passages of the drive that is different. Oil in the exhaust side of the drive means you have a leak in a drive seal. Need to pressure test whole drive if you just did the upper.
Yes the water pump impeller sends water up to engine, some is always going to cool the exhaust , when thermostat opens the hot water comes out of the engine through exhaust manifold(s) and dumps via the exhaust elbow(s) into the exhaust stream to cool it, goes down through the gimbal housing , through the exhaust bellows and ends up in the lake via the prop hub.
there are 3 bellows - driveshaft which should be dry of water and only have some grease off the gimbal in it , exhaust bellows which is open to the water on the prop end and doesnt matter if torn, and shift bellows, which if leaks will allow water in the boat.
Deep waters
I started the engine and quickly checked to see if water was being sent through to the exhaust. It was not. Shut it down within 30 seconds and checked the muff for correct positioning which it was. I assumed the impeller was bad. Dropped the lower unit and noticed oil and grime at the shift shaft and oil on and near the impeller housing and then noticed the same grime on the lower portion of the unit. As it was being cleaned up I noticed that the grime was gritty so I collected some to find out what was the grit. By chance the grit was next to a magnet on by bench and stuck to it. I would think there is a seal or seals that need replacing. The whole leg will be torn down, inspected and repaired as necessary by someone who is qualified to do that kind of work, I'm not. I'm very curious about how relatively large pieces of rust would get through. The shift cable and drive shaft bellows are dry the exhaust bellows is in good condition. Some pictures are attached.
