Beautiful Old Merc - Not Mine
jimmbo
Mercury called it Silent Neutral. However, if the ignition was a wee bit off, points worn, or especially, a Weak Battery, you often had Silent Forward, and Silent Reverse.
Mc Tool
ha ha ha :LOL:....silent neutral ...talk about BS-ing your way into claiming credit for something you completely failed to provide :ROFLMAO:
Mc Tool
Kiekhaefer had convinced himself that was gonna be the way of the Future...
I guess ya gotta remember the time it was produced , direct drive being fairly normal ....I bet a lot of peeps would have been happy to have one ....I sure as hell would like that motor on my classic boat now...if I had one :):)
jimmbo
It was used because all Mercury had at that time was the Gearcase from the 4 cylinder Motors, and they figured the Shift Mechanism wasn't durable enough to handle a 50% increase in Displacement that the Sixes had, so they removed the Shift Mechanism, made a couple changes and the Propshaft was always locked to the Driveshaft through the gears. By 1961, Mercury had a Full F-N-R Gearcase for it, and that bad idea was put to Rest, for the 1962 Model Yr
Berdink
Yeah, like:
'Now with Start and Go Technology!'
'No Neutral, No Wasted Fuel - Just Start & Go!
Gee, Waverunners are start and go. Luckily the jet drive slips a lot more than the prop drive.
Lou C
My Suzuki DF 2.5 has neutral and fwd only, to reverse you spin the power head around, lol!
On my old Fat-Fifty I had a choice of neutral and forward or alternatively neutral and reverse, due to work linkage and worn gearcase thrust washers. Reverse is overrated.
