I went and measured the rods from the donor motor and they were .004 longer. That is likely wear and not an issue?I’m wondering why there’s like .010” difference in length? GM did so many odd things like mixing SAE & metric fittings it’s not surprising. I guess try to get the ones for the head you bought measure what you have & compare. Adjustment of preload might make up any difference. A machine shop guy or engine builder should know.
no worriesI went and measured the rods from the donor motor and they were .004 longer. That is likely wear and not an issue?
Prob not wear just manufacturing tolerances. When you set preload on lifters normal you are compressing the lifter i Think .030-.050” so no issues as AD said.I went and measured the rods from the donor motor and they were .004 longer. That is likely wear and not an issue?
I believe these are just torque to 20 ft/lbs, unless I'm missing something. No adjustment. That's how I read the shop manual.Prob not wear just manufacturing tolerances. When you set preload on lifters normal you are compressing the lifter i Think .030-.050” so no issues as AD said.
