Propeller advice
rbwhiz
Ok.... You guys helped with my last boat. Was running great but Ended up throwing a ring and needs a rebuild. Sold it. But now I'm on a 2000 Bryant 196 5.0 merc carb, alpha one, Gen 2. So OEM it had a 14.5 x 19 prop. I put a cheap aluminum Amazon one on for now with the same properties. But def can't handle wide open. At 4/5s power, I'm at 4600-4800 and 45mph. Anything past that it goes up over 5000 and sucks air. Can't keep up or get faster.
It absolutely jumps up on plane. If I hit it decently, it's within 3-4 seconds. Extremely quick. I'm not sure how much adjustment in pitch, or a little bit more diameter, etc. I don't pull much, might a little, but more just cruising.
The one unique thing about the Bryant boats, the gas tanks is up front.
So.... Anyhow. Throw in your two cents worth if you wouldn't mind. Thanks for the help
Stinnett21
By "same properties" you mean the Amazon prop is a 14.5 x 19? Recommend a Turning Point 14.25 x 21 3 blade aluminum. They have a more modern twist on an aluminum vs some builders. Comes with a bit more rake and cup. I'm running one right now, love it.
I recommend a 15x19 stainless Solas prop
jimmbo
Diameter and Pitch are only part of what makes a Prop. Blade Area, Blade Shape, Constant vs, Progressive Pitch, Cup, and Rake are also factors. Change any one of those, even the slightest and it becomes an Apples to Oranges Comparison
Now about your Replacement Prop, does it have the same Hub Diameter as the one you removed? I have seen people think just because the Prop goes on the Propshaft, it was made for that motor.
I am partial to Mercury/Quicksilver, and OMC/BRP Props. I have found over the past 50 yrs, that the 3rd party Brands are all over the map when it comes to design, build and quality.
rbwhiz
I have no idea. Lol. It had a 4 bladed prop on it that was in bad shape. Had bad water burn on it and I just didn't like it. A 3 bladed STAINLESS 14x19 was in the boat as well.... But it's definitely had work done to it, and can't tell a thing about it as far as brand, etc. But I was able to find out that these boats did come with a 3 blade SS 14x19 on them.
The gas tank in the front, I've learned, is a good and bad thing at the same time .
jimmbo
"Cheap Amazon Prop" tells us nothing about the Prop you put on, other than it is 14.5 X 19 that is apparently blowing out at High Speed. Is the Hub on this Prop the same Diameter as the one you took off? What was the diameter and pitch of the 4 blade? The number of Blades is also a factor I didn't mention in my last post, cause I assumed you were taking off one 3 Blade and replacing it with another. A difference in the number of Blades also is important when choosing a prop
jlh3rd
everything jimmbo said.....and, some gearcases/props have a plastic ring that snaps into the gearcase or fits around the prop hub.
if it's missing that can cause ventilation issues also.
Try the Turning Point in 21P. They are pretty high performance and hold the water pretty good. They are also cheap enough.
Different year Alpha Drives had different gear ratios. So, if you get a recommendation on a particular pitch prop, it makes sense to find out what gear ratio you have vs the recommender's outdrive
rbwhiz
I want to say mine is 1.62? That comes to mind. I'll try and look it up again.
rbwhiz
Not sure about the diameter and pitch about the 4 blade, doesn't say on it. It was horrible. The boat stock came with a 3 blade 14x19 from my research. I was able to get my hands on that Amazon prop quickly, so I went with that for now. It's not doing that great so I'm just trying to get opinions on what to go with. I'm thinking SS, 14.5X21 of a decent brand. (And to answer your last question, I did mention that it had a 4 blade on it. And I put a "cheap 3 blade from Amazon on it". )
jimmbo
I suspect that Amazon Prop is quite a bit different from a Mercury Prop of the same Dia and Pitch. Quite a bit different, might seem like little to you, but most Boaters think a Prop is a Prop
rbwhiz
I'm sure it is. The whole reason I came in here to ask for opinions. The main lake I go in is quite deep .... So I'm thinking stainless. I just wanted to see what others thought. But to be honest I don't want to spend $1k on a Mercury prop. I'm more of a bang for the buck type of guy.
Buying the wrong pitch or style of stainless prop is an expensive mistake. I would dial in the pitch and style of the prop with an aluminum prop. When you have it, then go to stainless.
The OP stated that he can get 4800 with a 19P prop, and above that RPM he ventilates. Redline is 4600, right? I think he should try a 21P prop.
Stinnett21
My 5.0 MPI alpha drive (1.62 ratio) is turning the prop I mentioned in post #2 at 4920 rpm. My top range is 5000 rpm so that's dialed in pretty well.
