FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
I saw this on another forum at some point. Trying to determine if if the connector I have is capable as a scanner hook up. Additionally, someone posted a cheaper alternative to buying the actual scan tool.
That diagram reminds me of what you had to do to pull codes from the EFI system on a late 80s Toyota....paper clip trick and turn on ignition, the check engine light would blink out a code, that was what you got!
That is a MEFI (1 to 4) connector and while there are not many codes can be read, if there is one it can be done as your pic shows. Use a 12V resistor LED or a voltmeter with a tone function
Like mentioned above, if you're just wanting to read trouble fault codes on the MEFI ECM's only type then the following way using a multimeter is a safe and easy effective way to do it...
If you are wanting more viewable data then maybe checkout a MR500 Marine Scanner for your engine manufacturer model on both Ebay and Amazon as it may be of some help too though seemingly pricey as well.
