Rochester_Rob
Thread starter- Joined
- Sep 23, 2026
- 6
Hi everyone,
I have a 1973 Penn Yan tunnel drive boat with an OMC 250 inboard engine. My dad bought it when I was a kid. The engine is a small block Chevy 350. In 2022, the original manifolds had internal cracks that let water into the cylinders when I was winterizing the boat. I didn’t realize right way and ended up pulling the engine, disassembling, changing the rings, honing the cylinders, and reinstalling it with new manifolds. It ran great for the summer of 2023 but then started to make a noise I never heard before when it was under load. I now believe it was backfiring through the carb. I can’t find anyone locally that will work on this old a motor other than to just rebuild it which it may not need. I have been working on it off and on since. Now it will not even idle well most of the time (although it does idle well sometimes and I can’t figure out why it changes). I have changed the points, condenser, rotor, flat cap distributor cap, set the dwell, and verified timing is to spec at 5 degrees BTDC. I use ethanol free gas and have also tried to run it from a fresh gas can. I have verified fuel pump pressure and flow. I have run compression tests (cold, plugs removed, WOT), leak down tests, and used an indicator to verify the cam lift. The only things I have found to be out of spec is there is a little cam wear and compression variation is above 10%. The intake lobes only have 0-.004’ wear while the exhaust lobes are mostly .003 or .004 of wear but one is at .009. While the larger numbers are out of spec, when I chose to have the cam changed on a 1980 vette it had visually significant lobe wear unlike here. The other thing that is out of spec is compression which varies from 142 to 161 PSI, a little more than 10%. I am attaching a file where I documents 7 pages of history and what I have tried and while I am methodical, with my lack of experience, I must have missed something. I can’t expect anyone to read all that but I am including it. This is a fairly simple engine, what am I missing? I am also not sure how easy this would be to rebuild since it is a reverse rotation with a flat tappet cam. Thank you for any suggestions.
