Stainless Steel Rowboat
Tapper54
Looking for information on a 14 ft stainless steel rowboat I picked up at auction about 35 years ago. I have since refinished gunwale and transom wood, replaced the oak seats, added floorboards and rigged it as a musky troller. My preliminary search indicated it might be a StarCraft but the info I found was somewhat contradictory re length (12 vs 14 ft) and hull type (galvanized vs stainless steel). The info I did find was also over 10 years old. Any current comment/info would be much appreciated.
jbcurt00
Look around there's info in here
Re: A Stainless Steel Starcraft ???
Hello All-
We purchased a lodge and have about 10 steel starcraft boats. Some are 12' some are 14'. We are hoping to get them all back in the water. So far two have been cleaned up and painted the traditonal lodge colors. Does anyone know what colors they were originally? Found an ad on ebay that looks like ours it is from 1952. Here is a photo of one of ours.View attachment 141044
Hi,
Thanks! Not sure if it is ok to give out our name on this forum, don't want to promo the business, but we are in Trout Lake, MI. Some of them need quite a bit of work, but we love them, and think they go with our place perfectly.
This is the ad I came across. View attachment 141286
Mc Tool
Thats pretty cool .🙂🙂 Me likey
Tapper54
Boy that nose pice and the corners sure look like old star craft hardware.
Thanks. I was thinking that they looked hand crafted and were replacement parts. I take it then that you agree that it is a star craft. I've found a few references that star craft used only galvanized. Thanks to you and others for your input. It feels good to have answeres to questions I had for years. I had no idea this forum existed. Love the boat! It carriles momentum well between oar strokes, isn't overly heavy, is relatively easy to care for....and it looks good.
Tapper54
It's a bit tricky releasing muskies over the side however!
JimS123
Beautiful boat and excellent restoration. But are you sure it's not polished aluminum and not SS? If SS it must be pretty heavy.
Mc Tool
I dunno ,I have a friend ( yes I have some 😁) who is a sheetmetal worker , makes a few boat fuel tanks and I recall him saying about peeps wanting to make tanks out of aluminium to save weight ( and money ) and he doesnt go there because if you use ally strong enough it weighs and cost as much as the stainless......ergo a stainless boat might not be that heavy , and pressing ribs into stainless would be stronger than doing same to ally ....so less bracing required ?.🙂
Tapper54
I too had questions......It is stainless according to an engineer friend who evaluated hardness, welds and other structural characteristics.
IslandExplorer
You won't be able to scratch stainless steel with a pocket knife very easily. Try in some obscure spot. Aluminum and magnesium (like on a transfer case) scratch easily with a knife or screwdriver.
Crude easy pocket method to tell if it is SS or not.
aluminum and magnesium are similar. magnesium once set on fire will burn until its all burned up (you almost can not put out a magnesium fire)
stainless will be mildly magnetic if its 304 which is what I believe that the boats were made out of.
dingbat
Is there a high probability of mistaking magnesium for stainless steel or a straight forward way you know of differentiating the two? Thanks.
No.....magnesium will not "ring" and is 4.6 times heavier than stainless
The density of 304 Stainless is ~7.96 g/cm³ verse 1.74 g/cm³ for Magnesium
Tapper54
Thanks all. I have to go now. It doesn't scratch easy, it rings and it says ss, so I guess I'll go with that for now.
