Texasmark
Thread starter- Joined
- Dec 20, 2005
- 15,070
Re: Anybody Running NGK BUZHW-2 Plugs?
Anything you read on my March post is old news. I took the alum foil off almost as fast as I put it on. I am currently back to the original surface gap NGK plugs. I solved some other problems and engine is running fine again. Yes the plug wires radiate....my timing light plug wire clip just needs to get close to a plug wire (no need to clip it around the wire) to fire the light but it is not causing any ignition problems.
Mark
Mark
