Really dry around here
DeepCMark58A
Finally raining this morning, looks like we will get a nice soaker out of it. Glad I got the mowing done yesterday and the rain will clear before the guests show up.
Grub54891
Haven’t mowed the lawn in two weeks. The grass isn’t growing much at all up here in northern Wi. The little rain we do get isn’t doing anything.
FLATHEAD
According to NOAA we are in a severe drought in our county. We are only 3” below average for the year, not sure how that equates to severe. The lakes are at full pool for the most part.
WIMUSKY
Yeah we are spring fed too, guess I have been pumping too much water keeping the grass green
I quit watering the lawn because my submersible pump quit. Must of overheated, started back up an hr later. A new pump is probably in my near future...🙄
We didn't get squat out of the rain, or lack of this morning...
DeepCMark58A
You need to have a shroud around the pump and motor to route the flow of water past the motor to cool it. You could drill a 8" well in northern WI where the ground water temperature is close to 50 degrees put a 4" submersible in there without a shroud it will burn out. Submersible motors require water flowing at velocity over the outer skin for cooling.
DeepCMark58A
Take a piece of 4" PVC around the pump get a well seal for the top of the your pump will last for years. My first toy was a pump impeller I paid for my college education working for a well driller.
WIMUSKY
Gochya.
We've been here approx 30yrs and never touched it. Thinking it's probably original. The house is 35yrs.... So it's probably time...
dingbat
What am I missing?
My well is 275 ft. deep with a 1/2 HP submersible in it.
No shroud.....just hang off the pitless adapter and a rope
DeepCMark58A
4" well with a 4" submersible should work, a 6" well is ok but domestic water supply is different than irrigation. Irrigation is long run times, domestic systems are filling a 60 gallon pressure tank at 7-12 gpm
