Solar chargi g
rickasbury
Master Chief Petty Officer
I tecently had a problem with the city and bringing my boat home to charge is now a problem. I have two batteries on a battery switch. Can I reasonably get enough juice to them to keep them alive? The boat is a Rinker 270 express cruiser, the batteries are a long way from the outside of the boat to mount solar panels...a good 6' at minimum....what can I set up?
Depends.....
How often do you head out?
Is the boat stored outside or inside?
How low do the batteries get?
Any parasitic loads?
Our RV has a 250 watt panel and keeps two group 27 batteries charged. We use it at least once a month
You could always set up a 2-bank or 3-bank noco charger and a power outlet like I have on my boat
KD4UPL
You absolutely can keep the batteries charged with solar. Reasonably is anyone's guess.
I install off grid solar for a living. A six foot run of wire is nothing. You need panels, a good charge controller, wires, mounting hardware, and a few other bits.
Flexible stick on solar panels work well on a hardtop. Rectangular RV panels make more power per area. Residential sized panels are the cheapest, especially on the used market.
roscoe
I bought a BLUETTI Elite 30 V2 power station, and a 200 watt panel, for use when we camp off grid. Its a good quality unit, not like the el-cheapo knock off units.
Keeps our lanterns, phones, and the boat battery charged all week.
We put the panel out, plug the power station in, go fishing.
Then at night we put the power station in the boat and hook up to the battery.
You could just put yours in the boat and keep it hooked up. Just make sure you get a good panel and have someplace to place it.
airshot
How close is the nearest power outlet to where you store your boat ? Solar can work but it will get $$$ real quick.
DeepCMark58A
Would you buy a used solar panel?
roscoe
OK, but why are they run down far enough that they charging.
If they are charge when he parks the boat, they should still be charged 6 or 8 weeks later. Certainly not too far that a NOCO jump pack couldn't handle.
They should not run down, and therefore not need to be charged. End of season is different. Pull the batteries and bring them home to be maintained in the down season.
Does your boat have a parasitic draw?
airshot
A fully charged battery should maintain that charge for at least a month and while it may drop a little, it should hold enough charge to operate everything for at least two months. 12.7 v is a full charge...12.4 is half charge but still enough to get the job done. Below 12.2v is low but will work for non severe draw jobs. Below 12v is considered dead. Check with a digital voltmeter. I added a couple digital volt meters to my start and house battery, got them on Amazon at 2 for 12 bucks shipped to my home. Miniscule draw but can tell voltage at a glance. Best 12 bucks ever spent.
KD4UPL
I would for this application. I wouldn't sell one to a customer for a new installation.
I've helped broker some deals where a homeowner was selling used panels snd someone wanted them for s cabin or RV. Many homeowners are removing older 200 - 300 watt panels and installjng 400 - 500 watt panels. The old ones might only be 10 or 15 years old and they came with a 25 year warranty. The warranty doesn't typically transfer but it's a good bet they havr lots of life in them.
I've sold lots of used panels to hobbyists, amateur radio operators, rv owners, etc.
