electricjohn
Thread starter- Joined
- Dec 16, 2006
- 238
1988 3 cyl. 90. First time this happened. I did see oil on the ground last year. I run the motor out of gas when winterizing but leave whatever oil is left in the engine mounted holding tank. It appears the air and oil in the tank expanded with the heat this summer and was force thru the oil pump, gas pump, fuel filter then into the carb bowls till the float rose. Does anyone know why this is happening recently? I plan to leave the oil tank cap loose next winter or possibly drain it.
