Mercury oil injection - keep or delete?
burnt clutch
Hey all, I just bought a used 2001Mercury 40 HP ELPTO motor, and this one has an intact oil injection system. Are these oil systems reliable? The motor has good compression, so I’m assuming that it’s working as intended but I’m wondering if I should keep it or delete incase it fails sometime in the future. What are your all thoughts on the Mercury oiling systems? Are there any parts that I should check for premature wear? Thanks in advance!
-Karl
Texasmark
I had a 90 and 115 HP 2002 engines. I eliminated the oil pump gear on the 90 because I felt like doing it, obviously running pre-max gas afterwards. I didn't feel like it on the 115.
One thing I noticed and may have been the reasoning for the initial change is that I'm 84 and don't go boating much, maybe once per annual quarter for an hour or so on the water. Doing the things that I have been doing for decades, what you are supposed to do to get an engine started, but having to deal with the EPA mandated squeeze bulbs, fuel was taking awhile to get into the combustion chamber. Since the oil was injected by a pump geared to the crankshaft, as the engine turned over with the starter, it was pumping oil but not gas.
The result was a "smoke fog" when the engine started, clearing out the excess oil. Pre-mix solved that problem. I didn't do the 115 because I was too lazy by then and too lazy to take the boat out much. Was it a good idea to do the 90? Absolutely. If you boat frequently, it probably would be a waste of time and less convenient filling up if you just had to add gas to the fuel tank.
Texasmark
1550 hours trouble free on my 1987 3-cylinder 90hp. Oil lines should be replaced every 10 years or so.
I would change your input from "oil" lines to "petroleum" lines since I have evidence of fuel lines breaking down and filling up fuel filters with little black (rubber) specks.
