115 6c TOP piston cylinder issue
jimmbo
600-650rpm, in Forward was the Idle Speed Spec for those engines. I used to adjust them for 575-625, just to lower the Shock imposed on the Driveline when put into Gear.
Regarding your Piston Rings. You are checking their End Gaps in their assigned Cylinder at several spots, and adjusting if necessary before installing them on the Pistons?
ianmoore
Ive never installed a piston in a cylinder, so lets start there!
Do you have any thoughts on my question? I had compiled some notes on assembly. One person had mentioned checking end pin by turning the piston in the cylinder after it was installed.
My question/concern was that i thought the rings went in well and the pistons all seemed to behave similarly. I was under the impression that a ring not properly seated was pretty easy to feel. I think that the ring might have broken in the cylinder when i turned it to try to see the ring stops. Those ring ends would never come close to the ports on the side of the pistons, and possibly the gap got caught there?
I don't have ring compressors, so I was using fingers/plastic tools to install them.
I did not check the rings separately. I was following my merc manual on piston install. The only thing it said regarding rings was to test by pressing with a screwdriver after install to see if it had some spring
i had cylinders and pistons prepped.
I did my best to center the two rings around the ring gap
I then slowly compressed the rings until piston sat in cyliner.
i had one or 2 times where it didn't go in quite right and i gently pulled it out to redo.
jimmbo
Even though, in theory the Rings should fit, the Piston Rings Gaps should be checked and Adjusted to each and every Cylinder Bore. A lot of Machine Shops will require the Intended Pistons be supplied to them with the Block, so they can be measured(even brand new Parts can vary slightly in size), and the Cylinder is bored specific to that Piston. But the Rings are usually not fitted by the Machine Shop. Using the Piston to push a Ring down the Cylinder, insures the Ring is Perpendicular to the Cylinder Walls. The Gap in the Ring, is then Measured with Feeler Gauges, and the Number Recorded. There are several Specific Locations along the Cylinder Bore where the Ring needs to be placed and the Gap Checked.
If the Gap is too Big, the Leakage Loss will be higher than desired, if the Gap is too Small, the Ring will expand as the Motor Warms up closing the Gap, and Bad Things will then proceed to happen. A small Gap can be filed, and remeasured, until it meets the Proper Gap.
The Screwdriver Test is to Verify that the Ring isn't Broken.
The Pin is to, as you state, prevent the Rings from walking around the Piston, but they have been known to break too. Piston Rings, while Brittle, are pretty Tough, and can really chew up a Piston Crown and Cylinder Head bouncing around in the Combustion Chamber.
Rotating a Piston in a Cylinder, with the Rings installed is really not a good Idea
Installing the Pistons of on a lot of the Older Mercs, without the Special Ring Compressors, was a Challenge. 2 Sets of these were required on the Inline 6
It could be done without them, but it was not fun.
All the Connecting Rods with Pistons installed were attached to the Crankshaft and lowered together into the Block. On some Engines made after the 70s the Connecting Rods used End Cap Bolts that faced the Front of the Engine, on these, sometimes you could get away with putting the Pistons in first and then placing the Crank in. On the older Motors, the Con Rods had Bolts with Nuts that were located towards the Rear of the Motor.
If your has the End Cap Bolts, they are a One Time Use Only Bolt, and MUST be replaced.
ianmoore
Wow! Thanks for the details. This is all such an education.
I wish I had that communication and detail from the machine shop. Honestly, I thought I wasn’t going to be able to get anyone to do the work and was gonna be sitting on a broken block.
That said, I have very little detail on what was done. I am assuming the cylinders are slightly out of round, but was told that the existing pistons would work, so I ordered replacements.
I am going to go through the cylinders with rings to measure. I have the official merc repair manual, but did not see any info on this in the powerhead section. Perhaps it’s in a different place.
Yes, i wish I had the piston ring compressors, but I don’t, so will have to install crankshaft after pistons are in. Thankfully the rod bolts are the screw in type, so it is more doable
Gee, I hope I am not redundant. Usually, you use the pistons to push the rings into the block, so they are perpendicular to the bore. Then use a feeler gauge to check end gap and file to proper clearance.
Screw-in or bolts with nuts are about the same difficulty when reassembling the rod-to-crank. The hard part is sticking the rod bearings onto the journals and cages, with grease. It is not really hard, but tedious. Hopefully you separated the bearings and cages by rod, so reassembly is easier.
ianmoore
No! I appreciate the time and detail. This is all new to me. It is strange that it doesn’t talk about ring gap in the manual, but I’m going back through and measuring that now. I had about .006 at 1” and bottom in c2(standard). That was the one I broke the ring on, but again, think it was from turning it in bore so ring end caught on port. C3(.0015) was about .008 at 1” and bottom
ianmoore
I did split rod bearings, cages, and caps, by piston. I am getting some real micrometers, and a decent dial bore guage. I'm going to go through the cylinders and get some numbers. This is too much work to just slap it together(Ive rebuilt everything but lower unit) and I want to make sure it is all good. The machinist was just too vague
ianmoore
Spent the last day learning micrometeres and bore dials. The ones i got don't suck, but they aren't machine shop level. Here is what i have on the 3 im working on.:
lost compression in C1 and C6. Was taken to machine shop
  • Cylinders were not bored or sleeved.
  • Machine shop performed a light hone only.
  • New pistons and rings installed.
  • Piston diameters measured with a new micrometer at 90° to the wrist pin, 1/4" up from the bottom of the skirt.
  • Dial bore gauge was zeroed to each individual piston average, so the readings below are actual piston-to-wall clearance.
  • My measurements of the OEM pistons were slightly below what is published, and they were consistently so
    Piston Diameters​
    • C2 (standard): 2.8694"
    • C3 (+.015): 2.8845"
    • C6 (+.015): 2.8853"
  • Cylinder 2 (Standard)​
    • Top: 0.0010" / 0.0018"
    • Above ports: 0.0019"
    • Below ports: 0.0019" / 0.0019"
    • Bottom: 0.0019" / 0.0022"
  • Cylinder 3 (+.015)​
    • Top: 0.0023" / 0.00225"
    • Above ports: 0.0021"
    • Below ports: 0.0020" / 0.0020"
    • Bottom: 0.0020" / 0.0018"
  • Cylinder 6 (+.015)​
    • Top: 0.0029" / 0.0028"
    • Above ports: 0.0027"
    • Below ports: 0.0028" / 0.0028"
    • Bottom: 0.0032" / 0.0032"
  • Question:
    Given that the block was only lightly honed (not bored to fit these pistons), do these piston-to-wall clearances look acceptable for reassembly? The Mercury manual also states that a cylinder should be rebored if taper, out-of-round, or wear exceeds 0.003–0.004"
ianmoore
I am about to finish installed new pistons, but I’m trying to make sure all my measurements are correct.
This pistons measurement is confusing to me. It seems that it’s asking for 2 measurements but it seems they would clarify that. I don’t know how one measurement, at wrist pin, could both be “in line” and 90* at the same time.
My clearances are a little tight which seems odd on a ln engine that, if anything would be looser at this point. I am using the exact same pistons(new OEM) and I have to assume that they machine them to be somewhat interchangeable, or at least working a spec that would fit the cylinder.
ianmoore
OK. I think i got all of this somewhat straight. Mercury wording is a little convoluted and confusing, but the biggest measurement is 90* to wrist pin. All of my OEM are coming in a bit smaller than those numbers.
My clearances are pretty big, around 6-7 thousands on the 3 cylinders im looking at. My earlier post was user error. It took a bit of sitting there looking at the guage to realize, but I think i have it pretty close now.
The weird thing is that the machinist measured against my old pistons, which were all a bit smaller than the new ones( new ones are roughly .0017-.0018 bigger) and he told me the engine would be fine to re-piston and close up.
And, until C3 threw a ring I was getting good compression out of the motor for years, and it ran pretty well
I believe there was a spec for piston to cylinder wall clearance, as well as a taper of the cylinder max. If those are not in spec, it is likely the piston will lose a ring or seize.
ianmoore
yes. spec is .003. Im going down the rabbit hole because the machinist didn't provide this information and i wasn't comfortable re-assembling engine without more data.
ianmoore
I texted the machinist yesterday morning after my findings, and ended up taking the block to his shop. We were talking about boring all the cylinders, and whether to bore them all to .03, or take the standards to .015, and the 3 .015 to 30.
We took all the pistons out and weighed them on the gram scale. I was surprised at the difference. These are all OEM mercury pistons. It specifically says that different sized pistons are all supposed to weigh them same.
His take was that the weight disparity would be as big of an issue as the larger clearances i was concerned about and that if I wanted to rebore, he would want to go to all .03, and get them from the same place(as opposed to picking them up on Ebay).
He looked at me and said "I'll do it if you want to" and then said "If it was my motor I would put it together as is." He said it would perform fine and would not be an issue with throwing a rod.
He brought up an interesting point on clearances. We live on the Puget sound, which is really cold water(mostly high 40's). He said that the nature of the cold affects clearances, with the cylinder reaching normal operating temps, but the block staying cooler than a normal outboard, and that the .003 clearance would actually be pretty tight if you were boating in these waters. He typically would bore a couple of thousands bigger over spec for an outboard in ther puget sound.
I called a couple of guys that work on Mercs and they said spec was 3-4 on them, and that was the working area that most of the guys considered, and they both confirmed that most local motors are adjusted to a little looser here in puget sound to adjust for the cooler waters.
So, long story short, I'm putting motor back together without additional boring. We will see how she performs, and I will report back once i get her in the water. Im out of town for work for the next 3 weeks so it will be mid-late August before I can make anymore progress.
ianmoore
OK. finally back from work and back on the motor.
I was having an issue with getting the reed assembly bearing screw and nut tight enough. I assumed i had stripped the screw so ordered replacements.
The screw is "N" in the diagram. This corresponds to part number 45775, and the nut is 45774. I have cross checked this across mulitple websites
The nut is a stop nut and fits into a cavity that holds it. The manual clearly states that the torque is 85 inlbs, but i can't get to this without the screw starting to spin in the nut. I have the correct parts, and actually have bought nuts from 2 different sources. I used 2 different torque wrenches just to make sure there wasn't an issue there. I can get to around 60-65 inlbs before the screw will start to spin without tightening any more. it holds this torque but will not increase any
I checked one of the other reed assemblies(that was never removed), and it's the same behavior. so, i am concluding that this spec must be incorrect. It seems that the screw-nut assembly reaches a certain torque that keeps it tight.
Since this is in the crankshaft, i would love if anyone has any thoughts on this.
ianmoore
I got the screw to torque. Have the crankshaft set and all the pistons in. I will start attaching them to the crankshaft next week
ianmoore
Quick update. I have crankshaft closed up. Exhaust, waterjacket, transfer ports, head all on with mostly new bolts, all torqued to spec. Trigger is good, but one side of stator was reading a really high resistance, so replaced that. Once I get new one I’ll test CDI packs and ignition coils.
Then I’ll install rebuild carbs and fuel pump. New water pump.
I’m about to be touring for 3 weeks, so have about another week to get motor together before I’m gone. Raising end of summer, but still feeling optimistic that I can get boat in the water a couple of times before the weather turns
