Engine stalling when you give it too much throttle on take off
skyman2112
Carbureted engine, PCM 351 BOSS. So far tried rebuilding original carb, then purchased another factory style carb, then replaced fuel pump and then replaced the factory ignition and finally, got a completely different brand new holley carb. Nothing every changed, Stalls when you give it too much throttle from a stand still. In cruise, accelerates fine when you give it full throttle. You can see the accelerator pump working too. Really going crazy with this one. thinking vacuum leak maybe PCV valve?
kenny nunez
Have someone watch the secondary butterfly linkage when you punch it. The linkage should not move until the engine starts to turn up. If it does move try to restrict it and see if does not bog or stumble.
skyman2112
I have not checked that cause we tried 3 different carbs with the same problem, but its worth a look. Thanks
Grub54891
Have you checked the weights inside the distributor? Sometimes they get sticky or the springs break.
jimmbo
When you say "give it too much Throttle from a standstill", does that refer to how quickly you give it Throttle, or how much Throttle you give it?
Does the Stall happen the moment the extra Throttle is given, or a few seconds later?
When you "replaced the factory Ignition System", what parts were replaced?
Since the Carb, had been rebuild, and replaced twice, it is difficult to blame it.
Being a PCM Engine I will assume the Spark Advance is controlled by the Computer, not by a Mechanical Advance in the Distributor. Have you verified that the Timing does advance?
What about the Fuel Lines between the Tank, the Fuel Pump, and the Carb? Sometimes a blockage, can allow plenty of Fuel at a relatively constant flow, but chokes when there a sudden increase in demand.
Fuel Filter?
When accelerating from a standstill, the Bow of the Boat Rises, maybe that causes a change where Fuel is not able to be delivered. At speed, the bow doesn't leap up, when more power is added
skyman2112
Fuel Filter?
Happens almost immediately , from idle, too much throttle is referring to the amount of travel of the throttle lever. No too noticeable without a skier though.
Accelerator pump is adjusted correctly and can be seen working.
The entire ignition system was scrapped, upgraded distributor is a unilite with single coil, have not checked to see if its advancing.
Could be a soft fuel supply line collapsing but seems like it would have enough fuel in the float bowls to at least take off for a few seconds
Fuel tank is in the back so the pickup should always be covered.
Those are some great ideas. Im leaning towards a vacuum leak. It snaps your neck firewalling it at speed, and maintains 5000rpm all day long which seems hard to do without enough spark or fuel.
Lou C
Ever look inside the fuel tank via the fuel tank float hole to see if there's crud in the tank?
What about the pick up tube and anti siphon valve?
I also for sure would get a hold of an advance timing light and make sure the spark is advancing as it should.
Honestly I'd rather have a simple centrifugal advance with weights and springs than electronic, unless OEM modules are readily available.
Since you've had 3 different carbs on it with same problem, look at the boat's fuel system!
look here:
skyman2112
thats a great idea, the fuel hose is new from the tank and its been removed and flushed didnt see anything. Runs great at wide open throttle with high fuel demand. Maybe we need to resize the accelerator pump
skyman2112
nope its black. Still having the same problem after trying larger accelerator pump nozzles and faster cam
Scott06
Is your ignition advancing properly? 3 different carbs and same issue I would look elsewhere. Vacuum leak is also good to rule out spray starting fluid at intake to head seam. Have you verified fuel pressure. Assume fuel is fresh and not contaminated ?
Lou C
Probably it's electronic not a centrifugal advance unit
it is a tough problem because the engine picks up RPM at speed fine, it is just off idle that it has problems.
99yam40
still needs to see what the timing is at, and a timing light will show what it is, and if it is advancing when it should
