How to tighten up rack/pinion slack in steering
JonBoat55
Steering has always had about an inch of slack back and forth before engaging the tiler. I feel like it's gotten a little worse. Is this a normal amount of slack and how would I go about tightening it up?
  • IMG_1247.MOV
Ayuh,..... Odds are, the rack, or pinion gear, or the cable housing is worn,......
The "Fix", is replacement,....
dingbat
All connections tight?
Mine NFB helm was getting loose to the point I was researching new helms. Crawled under the helm to get a part number off the unit. Found both steering cable nuts loose. Quarter turn on each nut snugged them right up.
To answer your question, I’ve had roughly 1/2” of play since new.
nola mike
Didn't see what we're working on, but may want to check to make sure that your steering pin isn't worn out
JonBoat55
The slack ends at the end of the cable in the engine bay, somewhere in between the wheel and the tiler. First thing I did was go under the helm and see what could be tighten. Seems to be a self-contained unit, no steering cable bolts to be found. I was more wondering if it can be tighter in the engine bay section.
Ayuh,...... Sounds like the outer cable sheath has a grove worn in it, allowing the inner(working cable) to move, before it can push/ pull the tiller arm,...
Stinnett21
I replaced my cable a few years ago due to wear. The amount of play did not improve. I think it's inherently a bit sloppy. Thankfully under power I really don't notice it.
JonBoat55
Y
Yeah, under power it's a non-issue. Just thought if it was a simple fix, having tighter steering would be positive. Good info Stinnett, thanks
