I/O (Sterndrive) Conversion to Outboards
Which is why I suggested you have the admiral do it a few months back as she did your bathrooms....
You pay for the plane ticket and shipping my toolbox of DAs and sanding boards and we can knock it out in a few hours. Ain't nobody got time for sanding blocks
Pmt133
I never liked to do drywall. :rolleyes:
Anyway . . . everyone grab your sanding blocks . . . there is a 'block party' going on at my house. :ROFLMAO:
I got 3 DAs and 500 hours of sick time at my disposal. Don't tempt me.
Pmt133
don't die before you use it.
I use my vacation and personal. The hope is i eventually transition back into the professional group. In which case they buy down sick time at a 1:1 rate above 384. As it sits right now it's actually difficult to use all the time I earn as it is. If I burned all 500 now they wouldn't see me until october with how my schedule works from now on.
redneck joe
yeah i had about 350 when ATT bought us. They kept 'strongly urging' us to use it because they may not pay it out. Wife bought into that game, she got down to about 20 hours. I cashed in and we took a nice vacation.
tpenfield
Today was supposed to be a rainy day according to the weather forecasts. So, I planned to do the electrical work, given that the boat has the camper canvas up.
Of course, it was bright & sunny, :unsure: but I did the electrical stuff anyway, taking a break from the block party. :LOL:
The Honda engines (like the Mercurys) want 'clean power', which is a direct connection to the engine batteries. The clean power lead from Honda is 12 feet, and my re-power guy prefers not to have to extend the wiring. So, I moved the engine batteries aft to a point where the 12 foot harness would easily reach. Hopefully it will be enough.
I then needed to run leads back to the electrical boxes (Port & Starboard) for the switched portion of the electrical.
I also ran the fuel lines back through the extension bracket with 5-6 feet of extra safe measure.
Here is my handy work getting things laid out and fastened.
The bilge pump and related wiring is a bit of a rat's nest. . . . I'll have to sort it out.
One nice thing about my boat (Cruisers Yacht) is that every wire is labeled along its length with a name & number so it can be referenced on the wiring diagrams. (which I have)
Here is the wiring for the underwater lights . . .
These wires I found in the aft harness and they say "fuel sender" :unsure:
Kind of strange since the fuel tank is mid-ship.
The block party resumes tomorrow. 😁
Ted, did you pull the fuse for the trim tab pump? would hate for you to bump the switch and spray ATF into the fresh bilge
tpenfield
I met with the re-power guy yesterday . . . A couple of tweaks to the helm instrumentation . . .
A perfect storm of Honda, Veratron, Optimus, and Garmin . . . it might all actually work :ROFLMAO:
Stinnett21
Just wondering where is your sound system at? I have the same Sony remote you have pictured on far right. As far as I know their current units no longer support the LED readout that remote was intended to, and used to, display. For my cheap Sony head unit that remote's buttons still function but the display doesn't. If I lose my place I have to open the glove box to read the head unit.
redneck joe
tpenfield
In the cabin . . .
tphoyt
Is that joy stick for steering? I’ve never used one and would likely crash if I did. I was never big into video games.
My buddy just got a new Bobcat that is all joy stick. He learning but it’s not going easy for him.
tpenfield
Gelcoat day . . . My first time spraying gelcoat :unsure:
I put a coat of VE primer on a couple of days ago and today did the gelcoat. 3 layers, each done about 1 hour apart. The final coat had the Duratec hi-gloss and the surface wax.
I used nearly a gallon of gelcoat and a quart of styrene thinner. I started with a 2.5mm nozzle, but then went to the 3.0mm for the final coat. My air compressor really is not up to the task for continuous spraying, so I had to pause in between passes. The gelcoat started setting up on me in a couple of instances, but I got it cleaned out.
It's not perfect, and we all have our weaknesses. . . mine is fairing compound . . . certainly not in my wheel house. More imperfections than I would like, but it's done.
