How do I adjust the high speedIf your " cool looking " prop has too much pitch , then acceleration will be slow.-----Have you adjusted carburetor mixture screws for proper performance , yes , no or no idea how?
Update got a welder making a bracket so I can raise motor .Im going to try thatHow do I adjust the high speed
Hopefully that will also strengthen the transom as well. That much weight and hp will weaken the transom over a short period of time. If you have any pics of the motor on the transom they might help us make sugestions.Update got a welder making a bracket so I can raise motor .Im going to try that
Here are pictures .I raised it 2 1/8 inches. Now with the pin in the first hole the front of the cavitation plate is slightly lower than the bottom of the hull.When adjusted all the way back it is slightly higher.Im going to try the second hole first..mI just redid the transom.Hopefully that will also strengthen the transom as well. That much weight and hp will weaken the transom over a short period of time. If you have any pics of the motor on the transom they might help us make sugestions.
View attachment 416501View attachment 416502View attachment 416503
I just did the water test with the motor raised 2 inches.Its running like a scalded dog now.I also tweaked the high speed jet on the carb that helped some also.Now it's scary fast
