frustratedboater
Thread starter- Joined
- Jul 10, 2007
- 499
I have a friends 2018 Yamaha 115hp 4-stroke that was running very rough and sporadic idle. I shut it down and conducted a spark test to see if any cylinders were dropping. Fuel is good and pumping fuel well. I tested the ignition and I didn't see any ignition spark. Went through he typical- kill switch is operational, neutral safety at the engine is making contact.
I Ohms tested the pulsor coil and got a 520 reading and believe it should be around 360 (+/- 72). Is this correct"
