1985 AQ 260a Hose ID
eggs712
I've been trying to find these replacement hoses before performing a PDS bearing and other lower unit (280) service, but cannot find them on any diagrams. Does anyone know what they are called or even a part number?
eggs712
843235 Exhaust pipe.
Idle relief hose, not sure of availability.
Thank you. I also found a couple blowups showing 814473 instead, which is a plug with a hole in it. I'm curious: if this is correct, why the change?
captmello
I think the number you list is a plug if your not using the ypipe, not positive. The number I gave is the hose for ypipe idle relief.
