Trim limit switch wiring
affa
Hi, I’m replacing the trim limit sender,
But the connections are similar on both wires, do they work both ways?
Regards
Affa
Regards
Affa
Ayuh,...... The trim limit sender is a make, or break switch,......
The other is the sender for the gauge, which measures resistance,....
affa
Ok, thanks
So it will work both ways then?
alldodge
Ok, thanks
No
The trim sender is installed on the starboard side and has a brown wire going to the gauge. The other wire coming from sender goes to ground
The trim limit switch has a purple/white and Blue/white wires connected to it and it's installed on the port side
nola mike
I think OP is asking if the wires on the trim limit switch are interchangeable, not if the switches themselves are. If that's the case then no, it doesn't matter which wire from the switch connects to which wire on the transom..
