- Jul 23, 2011
- 52,396
yes, the rubber donuts (too thick to be an o-ring)
yes, pull the drive off.This correct ? There is a rubber gasket behind that plate
Ok it looks to be fine, PDS fits well no slop, any chance that plate could cause massive vibration, I assume it’s the bearing but incase it’s not is that a reasonable option to take apart and investigate? Perhaps the PDS it’s self.You can call it a splined thingy if it helps. A drive plate=damper=glorified clutch disc without friction material
