[SPLASHED] I/O (Sterndrive) Conversion to Outboards
tpenfield
More engineering on-the-fly . . . design change #6,157 :ROFLMAO: .
Given that the underside of the swim deck has as much fiberglass in it as the transom, I have changed the transom reinforcement, eliminating the struts that were to extend in the swim deck cavity, and moving the top 'crossbar' lower.
I've also heeded the naval architects advice and further reduced the number of fasteners, focusing on the outer areas.
26 fasteners on the face and about 20 on the rest of it (bevel sides, top plate).
Additionally, since the swim platform underside does not really need the struts that I had planned, I am going to lower the position of the 'crossbar' to the top of the transom openings, where it will be most effective in stiffening up the transom.
Also, taking out the wiring and hoses has lead me to see the need for an opening on the 2 side supports that attach to the outer stringers. Something like this . . . .
For the extension bracket, I am going to try 3/8" spacers (reduced from 1/2") to see if I can get a slightly better fit (and also use less hull putty). Speaking of which, I'm picking some up tomorrow AM. SS (316) bolts are on order, so hopefully the bits and pieces are falling into place. :cool:
The Admiral has offered to help paint the bottom, so as to speed things along when the time comes for launch preparations. I told her that part of the job includes scrubbing the caked-on algae off the bottom first. :LOL:
redneck joe
So, wife is gonna scrape dried on crap from your bottom. She must really love you....
Im sure I missed the na thing on reduced fasteners. Is it similar to general construction where more can be worse than a couple, reducing overall strength?
The Admiral has been busy doing make-overs on the bathrooms. Fortunately there is one bathroom recently re-done so we have a place to :poop:
Her commitment to me, so as not to distract from my boat bracket building, is to do most of the work herself.
Ted is going to owe the Admiral
tpenfield
The words for the day are 'pressure washer' . . . :ROFLMAO: that will do the trick.
I think I there may be a new pressure washer in my future, because the reigning machine had a throttle/governor mishap.
Anyway, I've been trying to get this 'bonding plate' off the transom for the past few weeks. In our discussions of 5200 adhesive, if it is 5200, it must be the good/old stuff. It held on with all of its might until I cut the last bit of it. In trying to pry it off, the thing just laughed at me. So, I reverted to cutting the adhesive with a variety of sharp tools.
Also, in our discussions of fiberglass cloths, who would venture to say what cloth # is that shows on the transom? :unsure:
With the plate out of the way, I can do the grinding in preparation for the transom supports.
5015 debonder from worst marine works to loosen the bond of 5200
tpenfield
I picked up the Hull & Deck Putty this AM . . .
It is poly-based, but hopefully will be OK, considering I'll be scarf joining the extension bracket to the hull as well as my 50 +/- bolts.
My plan will be to start the putty cold (60˚F ish) to slow it down, then add heat to the E-B once it is secured.
In the fine print it says you are not supposed to drink while using it :eek: . This could be a problem, but perhaps a few beers afterwards. :ROFLMAO: 🍺
flashback
Why didn't you get the #405, seems it has a longer working time? Living on the edge eh.
tpenfield
I am cutting the Coosa board for the additional stringers and transom supports.
I have another unit of measure for @redneck joe . . .
These 2 pieces are supposed to be the same dimension, but the one up top is off by a 'smidge' . . . :unsure:
you used the CH tape on one and the RCH on the other?
tpenfield
A day of cutting and grinding . . . . I got a lot of the transom reinforcement structure cut . . . still a few more pieces to go.
I hope to be glassing this in over the next couple of days.
alldodge
No engineer here
I'm seeing the many structural supports built into the OB structure. Don't see how that will ever have a chance of failing. The boat came with twin 6.2's which has max HP rating of 350. All the force was placed on the original holes placed close together and there is no design error
Now there is a structure fastened to the same transom and moving most of the force away from the center keel.
Why does it need that much more support inside the boat?
tpenfield
Good question and I am glad you asked . . . I can answer that with a series of drawings that track the forces created by the engines, through the extension bracket, and on to the transom and the stringers within the hull.
#1) The forces of the engines (note that the force placed on the transom by the outboard is 2X the force of the sterndrive for the same HP).
#2 These forces are factored up for safety and then transferred to the extension bracket. Some reasonable assumptions are made as to how much force goes to the various stringers in the E-B.
#3 Then it is a matter of those forces being transferred to the transom of the boat. Note that the forces are higher up on the transom than the sterndrive equivalent and in greater amount. Without the supports extending up to the top of the transom, it will be relying on the existing stringers which extend only 1/3 -1/2 of the way up the transom. In most cases, the transom joint at the stringers would be over-stressed and likely fail. The supports provide a path for the forces to be transferred to the stringer/hull that otherwise would not exist.
redneck joe
Im a wee bit wobbly being a batchelor at the new house for a couple nights. I read the specs when im up tomorrow.
alldodge
Guess I'll have to take you word for it. Being 2X the force than I don't see how the Crap --- arrel stays together going from a SSX 30 to a 280 OSX. I have no stringer extra anything inside the boat. Sure my 280 only has a 25.5 ft hull
Than we can compare the Formula 310 sterndrive or OB, the interior hull is the same less the holes going to OB
