redneck joe
- Mar 18, 2009
- 15,383
So I've seen the fiberglass numbers for years, what do they (and csm) mean
Silicone can fix everythingThats a lot of math.
How can one adjust after the holes are drilled?
Maybe discuss with NA but I'm thinking the drive height might benefit higherI got the 5 gallon pail of VE resin, but the delivery person must be holding my 1708 cloth hostage or something. Awaiting a ransom letter. . .
Meanwhile . . . I have taken a look at the transom. Flatness, height, bolt positions, etc.
Flatness: I am thinking that I could use the cut-out pieces of Coosa from the transom along with some fiberglass putty to make/form a flat area (red dotted line)
Transom/Engine Height: By my best measure . . . the top of transom is 30.5" above the planing surface at the mounting point of the outboards. The spec. of the shaft length is 30.1" . . . making the ventilation plate a wee bit (0.4") above the water stream. There is a 'rule of thumb' when extending the outboard on a bracket . . . 1" of engine height for every foot of bracket extension. I asked about the science behind this 'rule of thumb' on another forum and a bar-room brawl ensued.
My splashwell bases block the lower position on the top series of holes. That should not be a problem, as the upper holes are what matters. FYI - The BF350 gets 2 top bolts on each side (i.e. 4 bolts) and then 2 lower bolts in the slotted area.
In my on-water testing after 'splash day', if it looks like I need to raise the engine, I can probably get 0.5-1.0" inch without any problem.
The bolts stay where they are. The engine gets moved up to another set of holes. That’s how engine mounts work.Thats a lot of math.
There's no stupid questions sir. The dumbest are simply the ones never asked.Ah, forgot about that. I've only mounted one outboard.
And side note, my seemingly stupid questions are all asked thru ignorance (or as in the above forgetfullness) but as with all my life I've always been the one to ask rather than pretend im cool and all that sh.t so others don't feel stupid for asking questions.
This thread is highly technical and I will retain about 5% of what I read here but others may gain more than me. My first post on a boat forum in 2005 or so was about a bayliner boat on tht. I was roasted without mercy. After my initial embarrassment I decided to be the one to ask stupid questions so others did not have to feel what I felt 20 years ago.
So, answer my stupid questions.
Yes, I'll probably combine a few methods 'a La' drywall smoothing. Often when doing stuff that is non-textbook, I see what is working and adjust accordingly.Ted, I think you are making the flatness harder than it has to be. Think body work or drywall work or concrete work. Large flat knife or spreader to spread the PB. While wet, use a 2x4 and float the surface.
Smooth out with the spreader. As it starts to kick, hit with a large flat-board sander with 40 grit. (Because sanding reinforced PB after it cures is like sanding concrete)
Then go back and hit with 80 grit
Sorry, 1708 for example is 17 oz biaxial cloth stitched to 3/4 ounce csm. 1808 is 18 ounce and so on. CSM is chopped strand mat and is sold by weight.Still waiting on answer for all the numbers question.
I think pb is peanut butter of course reference epoxy mixed with chopped strand of some number fiberglass.
This question . . . ?So I've seen the fiberglass numbers for years, what do they (and csm) mean
