Delco EST Wire Harness Question 3.0
rdj5905
Ahoy! Long time listener, first time caller. (I think. lol) Anyways, I have a 3.0 that a PO swapped in a Delco EST dist but their wiring job was subpar and doesn't look correct. Found diagrams to follow on here but I'm wanting to start fresh so I know what I have. Are the Delco EST harnesses universal to the 4-6-8 variants? I see Ebasic has a harness for a V8 but it sure looks correct for a 3.0 also. Just curious if anyone may know.
https://bpi.ebasicpower.com/shop/al...RzdEy8Goz1WePUFGuol3iMQu5Za6VVXvAkpeGMaX_qQzR
Thanks,
Jeramie
alldodge
Welcome
Yes the Harness and module is the same, but ----- the distributor is not
Meaning the cap and rotor are different
rdj5905
Welcome
Ahoy! Thanks for the response! Ok cool, exactly what I was thinking. Thank you very much!
Scott06
if you haven't used these types of low temp solder connectors before they are fantastic. uses a heat gun vs torch to melt the solder inside the heat shrink
