LiFePO Batteries ???
tpenfield
RE: LiTime . . . My replacement battery should be delivered today :oops:
I did not think it would come this quickly. :)
tpenfield
FedEx delivery person just showed up . . .
My replacement battery . . . !!! :D
Now I have something to fill out the rest of my day.
They also delivered the case of special beer that I ordered. (y)
are those tire tracks from the fed-ex truck?
tpenfield
Quick update . . .
I ordered another battery box to match the ones in the boat, because who wants to look at mis-matched battery boxes? It took over a week to be delivered, so installing the 3rd LiTime battery will be on the docket for next week.
I installed a toggle switch so that I can chose when to charge the LFP batteries from the alternator. Mostly this would be done while cruising back to home port when the battery bank is looking depleted after a day at the sandbar. I think this will work out better than the voltage related controls/settings that I had previously. Those settings are still in place, but the toggle switch is the master.
I think the inverter will be happier with 3 batteries in the house bank (total of 300 Ah)
tpenfield
Quick update . . .
While the system has been doing its charging thing while the boat lives on the mooring, I have noticed a few over voltage situations from the solar charging (via the DuoRacer controller). From what I can tell, the over voltages are brief, ( maybe a few seconds or less) and show up on the Xantrex Inverter as a fault. Not sure if it forced the LiFePO4 bank into protection mode (or not).
One of the geniuses on the DIY Solar forum suggested that the DuoRacer may be causing the over-voltage once the LiFePO4 batteries reach full charge and shut off their charging, and just for an instant, the DuoRacer has current with no place to go. (seems like a plausible explanation). . . :unsure:
As a test, I have connected a BFC (big capacitor) to the circuit to absorb any rapid change in voltage. I'll see if it makes any difference over the next few weeks . . . i.e. if over voltage situations are remedied.
Keeping up with the changes, here is my latest diagram of the system for your viewing pleasure :LOL: .
Summary of changes:
- SPST switch for DC-DC activation
- Removal of Alt/Batt isolator
- Capacitor for House Bank (LiFePO4)
tpenfield
Quick Update . . .
I've only used the boat a few times since making the latest set of changes to the off-grid electrical system, but getting rid of the 2 alt/3 battery isolator was a godsend. The alternators are happy and consistent 14.2-14.7 volts
The BFC (capacitor) has remedied the over-voltage glitches, so life is good for the time being.
I still have a third LiFePO4 battery to install, but that may wait a few more weeks.
tpenfield
I've installed the third LiFePO4 battery to the house bank. Fortunately, I had all 3 batteries within 0.03 volts of one another just prior to the installation (13.39 - 13.42 volts). So, hopefully they will be happy as a group.
After a day at the mooring with solar charging, all seems good (13.7 volts). The house bank is now 3 x 100Ah @ 300 amp maximum current (theoretical) :unsure:
tpenfield
Winter 2026 update . . .
I've kept the batteries inside for the winter. . . 4-1/2 months so far. I thought to check the voltages today. Each of the 3 batteries was sitting at 13.22-13.24 volts. (y) :cool: I have them charging now for a 'wee bit' so as to go the distance on the remaining winter.
Mc Tool
I just replaced the Motobatt ( yes USA made 😁) agm battery on my quad .....I think I killed it by cranking untill it was dead flat ...and then some ...but it was near as dammit 20 years old .
airshot
I also Put my look battery in the house for the winter. TimeUSB recommended cycling the battery every three months while not being used.
Easy enough to charge it up, let it set a few days then discharge back down to 50% with the BMS. Just finished my cycle last week. Next time should be boating season....hope....hope....hope..!! In the three month storage period, it dropped 1%....
M9.9
Thanks @dubs283 . . . not overly concerned about the cost of fuel, just thinking shedding 400 lbs. of weight reduction might help time-to-plane and boat balance.
The dry weight of the boat is 11,300 lbs +/-, so 400 lbs is not a game-changer, but something to consider.
Wondering if the LiFePO technology is solid enough, since much of the information online is more of an advertising nature.
Watch this:
