Opinions needed - Risk of Changing Thermostat
saltchuckmatt
Brick laying and joint repairs will be increasing in demand as millions of buildings pass the 100 year mark, residential plumbing & general repair will be in increasing demand same for electrical work , roofing jobs & all the things AI can't do. ex: at 76 I did not feel safe working 25 feet up a shaky ladder to change a kitchen stove fan vent flat birds kept invading ! ($100 for 45 min.)
"Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.” Albert Einstein
I must agree, but "common sense and persistence comes to mind". Matthew Paulsen
Actually I was thinking about using this, but I'm not sure if the sensor leads can be extended.
The black and yellow wire are energized if the temperature is out of range. I can hook that up to the existing siren, and as an added bonus you can monitor the exact operating temperature.
i have literally dozens of fully tested used 200f temp senders. they came in basically every motor from 1978 or so on up through late 80's when the charged to the tan/blue stripe which was around 240f. i usually replace the 240f ones with the solid tan 200f. the quickstart ones are impossible to find new but used look for junk heads on ebay with the sensor still in it. the tan temp wire just ground it to the block with the key on and see if it screams?
saltchuckmatt
Very well said.
dingbat
Must be from out West….locally, we crossed the 100 year mark almost 100 years ago.
The two of the three wealthiest individuals I know owned landscaping businesses. The third owned a HVAC company.
Crosbyman
like I said ...anything AI can't do :) incl changing diapers for boomers !
