- Mar 8, 2009
- 44,419
As Scott said coil is finePerfect
You just saved me $400
Do I need to change anything on it for the carb conversion?
I will put a new coil on. The old one looks tired.
Thanks
Timing is done as follows the difference will be DO NOT use timing listed (2*), you will need to use most likely 8* BTDC. You also do not have a shift interrupter
