[SPLASHED] I/O (Sterndrive) Conversion to Outboards
Scott06
My retirement job (sort of) . . .
Nice definitely not a lot of guys doing that kind of work anymore.
I did the interior of my 65 GTO but I was just putting covers on that were made by Legendary interiors, so I wasn't making them...
tpenfield
Yes, apparently I do good quality work and don't charge enough, so they keep coming back. :ROFLMAO:
harringtondav
Holiday Update . . .
I hope everyone is having an enjoyable Holiday season. We hosted Christmas and the kids/grandkids have been staying with us for the week.
Fiberglassing has been on hold while the family is here to avoid the possibility of fumes in the house. Meanwhile . . .
1) I have been continuing to clean-up the outdrives of the 'old' motors, using the non-caustic paint remover. It works pretty well.
2) I also have looked into the engine choice and the Dometic Seastar Optimus stuff, which is all the high-tech electronic controls the the boat will have. As I gather information it looks like the Suzuki motors may be the easiest to integrate. I was leaning towards Mercury, but I keep running into potential gotchas on the compatibility of Mercury controls with the latest & greatest Optimus components. It seems to me that Mercury is more geared to the OEM market with their JPO, and not as easy to deal with in the aftermarket. ( let me know if I have the wrong impression :unsure: )
If I went with Yamaha, it would be all the Helm Master EX stuff. Pricing and convenience will tell the story.
One nice thing I found was that Optimus has a Bill-of-Material generator on their website, which has been helpful in understanding the components needed and the cost.
3) I'll be interested to see how the final 2025 figures on the boat market look. It seems that things have slowed down for boat sales in general, and I'll be interested to see how the outboard figures look. (hoping to get a good deal on the engines, which ever brand I choose).
4) My project schedule is sliding a bit, given the winter temperatures. I was originally hoping to be sending the boat off for re-power in the Feb/March time frame, but that may be more like April.
Anyway, I'll be back at it doing the fiberglassing after New Years.
Wishing everyone a happy & safe 2026. 🍾
Your design drawings calculated several important factors, CG, forces etc based on a specific O/B package. Do your alternatives above fit within your design?
tpenfield
Oh, I think I know what you are asking . . .
I used the higher weight of the OB's under consideration and also the thrust of a 350 HP OB, whereas I plan on going with 300's.
In terms of strength calculations, I have been using 25,000 psi tensile strength for the fiberglass. Each of the 3 stringers can take a 30K lb load, based on the amount (thickness) of fiberglass used.
The compressive loads have been more guesswork, but they are probably substantial enough.
tpenfield
Also, I just came across a piece of information about the Mercury OB option . . .
It looks like with electric steering and DTS, then JPO can be added on a re-power and the 'personality profile' can be created for an individual boat. This appears to be a recent change, but certainly a welcome change.
Any Mercury Gurus feel free to verify/comment.
tpenfield
I am getting close on the internal structure of the extension pod. One tricky aspect of the build will be glassing in the internal areas of the transom pieces. I laid them in place, just to get a sense of the access and reach that I will need. My plan has been to access the insides via the splash-well openings. I do need longer arms, but I'll have to make do.
Here are a bunch of photos . . .
The splash-well openings are about 12"x20"
I've got the lateral bracing pieces in place and two somewhat thin ribs to stiffen the outside walls. . .
I got to order some more bi-axial cloth and some resin to finish this off.
Ted, do you have any skinny grand kids you can suspend from the ceiling thru the openings?
tphoyt
This works to. It’s my buddy repairing a water meter.
I love following this build. I’m excited to see the finial outcome.
harringtondav
That is the gist of my question. I don't know the weight and thrust differences of your possible O/Bs. ....looks like you left yourself good safety factor/wiggle room.
tpenfield
I just got back from the New England Boat Show (Boston). I talked with reps from the 3 brands of engine that I am considering.
It looks like I should get my work done in the next 2 months and get tyhe boat over to the shop of my choice by March 1 . . . otherwise it starts running into the shops doing the regular prep work for their customers.
Ted, did you sell the I/Os?
I would go 350hp.vs 300
harringtondav
If you get into a time pinch for March 1 can you have the motors installed and work around them for finishing details? Gelcoat is an example.
