Warning horn not getting ground
Jeanric
I have a 1994 OMC Cobra Ford 5.0 Engine. The warning horn does not work, whether when I turn the ignition on, or when I simulate a failure by grounding the oil pressure switch.
It gets +12V through the purple wire, but not -12V through the tan wire. Where should I look next?
jimmbo
Try grounding the Wire that Goes to the Pressure Switch, with the Ignition on.
Of course the Horn, might for be an Overheat
make sure you are grounding the correct wire. If I recall, there are 2 connectors between the temp switch and the main harness. make sure you have continuity.
Jeanric
That's exactly what I did in the first place. But ground does not arrive at the horn.
Jeanric
Can you share more about these connectors? It's impossible to follow the wires through the harnesses.
Start at the sensor, and worth towards the big cannon plug. Use the schematic as the guide
Jeanric
Reading your Initial Post, you said you grounded the Sensor, not the Wire going to it
Well i grounded them both, the sensor still attached to the wire. But even just grounding the wire does not activate the ground at the helm. Any advice?
Jeanric
Everything is inside harnesses that I'm reluctant to open up. I can't find a schematic detailed enough to help. Do you have one?
I do not have one, however I googled it and found one on a different iboats thread
jimmbo
Some Basic Troubleshooting for open/corroded Circuits. Have you verified that the Horn works, when supplied power directly from the Battery, using 2 wires?
Jeanric
Thank you, but it doesn't look relevant.
Jeanric
yes of course. The issue is that the path from the sensor wire to the dashboard is all hidden in harnesses. I can't figure out how to access a midpoint. There's probably one at the ECU though. If I manage to find it, I might be able to tell if the lack of continuity is before, after, or in the ECU itself. I'm not sure how much that will help.
jimmbo
Might have to run a New Wire, taping it to the Harness
Jeanric
Sure, but first I need to know where it goes. The signals coming from the oil pressure switch, and from the engine temperature switch, are supposed to go through the ECU which in turn activates the horn. So far I'm not able to figure out which ECU pins are involved.
Jeanric
What part of the schematic isn't relevant?
It doesn't tell me anything I'd want to know. For instance, which pins of the ECU receive the oil pressure and water temperature signals, and which one activates the ground on the horn.
muc
Hi @Jeanric
Is this something you're still working on? If so I might be able to help.
The Ford ECA (what you are calling ECU) doesn't work the way you think.
What symptom caused you to look at this S.L.O.W. system?
Horigan
Along those lines, I don’t get a warning horn when the oil or water switches are activated, but the SLOW system does engage.
Jeanric
Hi @Jeanric
Hi, the email notifications don't work for me, so I'm only seeing your message now. Thank you for your offer.
I started looking at this because I saw somewhere that the horn is supposed to come on for 1 or 2 seconds when you turn the ignition on, which it doesn't. grounding the wire connecting the pressure or temperature switches doesn't produce a sound either.
Further investigation showed that there is simply no wire in the harness that would connect the horn (in the dashboard) to the engine bay! I'm thinking of putting one in, but I'd need to know where to connect it on the engine side.
