[SPLASHED] I/O (Sterndrive) Conversion to Outboards
tpenfield
Also, I've seen a fair amount of 'traffic' on FB Marketplace regarding the sale of the Mercruisers.
Thousands of views and about a dozen nibbles, but no hard bites. I think the engines will be with me until spring time, but probably a better time of year to sell as a re-power.
alldodge
Thousands of views and about a dozen nibbles, but no hard bites. I think the engine will be with me until spring time, but probably a better time of year to sell as a re-power.
I hope your right, but I see salt water and Cats, the two things that would give me pause
tpenfield
I think that someone who runs only in fresh water may be hesitant, but for those who run I/O boats in salt water, not so much. For the inquiries I've gotten, CATs and salt have not been a main topic of discussion.
tpenfield
More gusset cores . . .
26 gussets in total (on the inside). There will be a couple more on the outside. Next steps are to glass all these things in. The gussets are intended to support (stiffen) the flange area around the structural members, as that is where most of the bolts will go.
The extension pod is getting heavy. So, I may weigh it after I glass the gussets.
flashback
It's starting to look like it's been milled out of a solid block.! I bet it is getting heavy.
tpenfield
Weep holes installed . . . before I forget to do them. :unsure:
I got some special tungsten carbide hole saws to drill through the bottom of the stringers. 6 holes total so as not to trap any water.
sounds like a "hold my beer and let me dull them" event.
fiberglass and 17-4 stainless both dull bits and saw blades and hole saws in very short order.
tpenfield
The larger (2") hole really put up some reactionary torque . . .
The holes saws (tungsten carbide ?) worked really well. Nobody had to hold my beer.
tphoyt
I got a cheap set of those on Amazon a few years ago and for the price I’m still impressed.
I even got into a jam on a job in the middle of nowhere yesterday and didn’t want to make the 45 minute drive to get the right bit so I used it on tile and is zipped right it.
tpenfield
Mass production of gusset fiberglassing . . .
I have over 20 gussets to glass in. I tried a couple of them 'free hand' and the results were OK, but not great. So, I made a template on my computer and laid them out on a large piece of 1708 cloth.
Don't tell anybody, but I lightly glue a sheet of plastic to the '17' (biaxial) side of the cloth, so the pieces stay together and don't fray during the cutting, handling, and wet-out.
Here is the 'master' sheet with all the gusset pieces marked.
Then it was a matter of cutting out the individual cloths.
I did the secondary stringer gussets (12 of them) fairly quickly and can get the others in the AM.
tpenfield
The gussets around the main stringer/girder are a different sort of shape. Kind of like a square and a triangle on top, but the cut-out method worked well . . .
Four gusset shapes soaking up the resin on the 'wet-out' table
If my counts are right . . . 26 gussets done
