Please help with HPDI issues
Stilletto
Got it in today, haven't had a chance to install it yet. If it doesn't solve the issue, the same seller has tons of mint parts that I may need also.
Stilletto
Didn't work.....runs the same exact crappy way.
I noticed that when I pull several spark plug wires, there isn't much/and effect on the way it runs even in gear
99yam40
those motors limit RPM in neutral by cutting off more cylinders that just the 2 it drops in neutral
make sure the motor knows when you put it into gear.
it may not be getting the signal it is in gear
Stilletto
I'll check that in YDS for sure. I ordered 6 coils and 6 new plugs.
After those things, i'll be at a loss.
Stilletto
I also noticed that if I pull each injector wire (one at a time) the rpm picks up and smooths a little. This suggests to me a global over fueling situation, or inconsistent spark.
99yam40
what tells the ECU the motor is getting proper fuel on these motors?
does it have an O2 senser?
maybe nothing.
it depends on the High pressure pump regulator to have the correct pressure.
did you make sure the ECU knows when it is in gear yet?
Stilletto
It does have an O2 sensor. It tests OK and I cleaned the "sniffer tube". It was quite nasty. I will check the neutral switch operation thursday in YDS. I did have a problem with it before but I had it working last time I checked.
Stilletto
It reports voltage in YDS as within spec but you never know I guess.
I got the coils today, spark plugs tomorrow.
Stilletto
Bought a new battery, coils and spark plugs installed. No change. I went out yesterday and idled around the river. Smelt really strong, not a raw fuel but like a 1969 Nova with no catalytic converter.......never went above 1000rpm.
I also bought a spark tester to see how strong the spark is. Comes tomorrow. I am wondering now about the stator, pulser coil etc.
Stilletto
Spark looks orange and not very impressive from all 6 coils. I am suspecting the stator now. Anyone had experience with a weak stator?
99yam40
get the proper test equipment to measure the out puts of the different coils
Stilletto
Agreed. Tomorrow I will measure the voltage coming from the stator also.
99yam40
the stator has the charge coils, pulsar coils and lighting coils.
your service manual should give you the minimum peak voltage readings for each going to the CDI.
I am thinking this is a CDI controlled motor
Stilletto
ECU actually. And from my understanding, rarely the issue but there's always exceptions
Stilletto
The voltage from the stator is very confusing. If I unplug the single green wire and measure the voltage, it's at 25 volts idle, which sounds OK. But if I plug it back and backprobe, its at 10v. The voltage on the two green wires going to the regulator is also 10v when plugged in but 25v when unplugged and tested.
But it gets stranger. If I leave the single green wire connected (the one going to the ECU) and backprobe it while disconnecting the regulator it drops to 3 volts.
If I backprobe the regulator while disconnecting the single green wire its at 15 volts.
Also, the 3 green wires are kind of warm.
Stilletto
I tested the stator as per the Yamaha specs and it is functioning properly. The coils are able to spark 1 inch consistently. Motor just running very rich and smoking.
60 seconds at 1500 rpm and the plugs are black.
If I unplug the injectors wires from select cylinders, the rpm raises a bit and it smooths out.
99yam40
you still have not said what the rail pressure is at or if the ECU knows when the motor is in gear
Stilletto
I am assuming you mean the pressure in YDS of the HP fuel pump? That's 675 at idle and 750psi at 1500rpm. YDS also does correctly detect switching from neutral to gear. Also, VST pressure is steady 50psi
99yam40
if everything is in spec but still running too rich, then you may need to try another ECU
did you have the injectors tested/cleaned and make sure they are the correct ones
