1978 Islander 22 I/O
66Holiday924
Starboard Cabin Window Rebuild
This would be my first window rebuild ever. I think it came out pretty good. I replaced the glass, with plexiglass, so, a little bit of a downgrade, but I had to if I want the side windows to match the front cabin window that has to be rebuilt.
The old butyl tape comes right off with the heat gun. You can see the information for the glazing that I used in the pictures.
I'm just dry fitting them for now. I will do the permanent install after I have it painted.
66Holiday924
Rebuilding the cuddy bench. They're not done, but you can see what it's going to be. I still have to revisit it and add a support structure. It looks like I'll also be able to add a significant amount of floatation foam too!
I decided pretty early on that this was going to be a fishing boat and that the cuddy was going to be a storage cuddy for fishing gear stowage and privacy to use the port-a-potty.
So, with that in mind I was trying to think of different ways to stow some of the things I will need for the operation of the boat and to fish and I came up with the recessed bucket idea. I got the buckets online from a farm store. They're very thick rubber and their intended purpose is to put feed in for horses. They sit down in the cavity, so they are locked in place. On one side I'll definitely have my anchor & anchor line and on the other, I'm thinking downrigger balls. I purposely chose these buckets because of the handles. The handles will make it easy to grab the anchor when I need it.
Anyway, it's still a work in progress. Still have to go back with some support and floatation foam.
SHSU
Lieutenant Junior+Starmada Splash Of The Year 2019
Very nice, wish I had one big enough that I could do a potty as well. Do you have enough room if you have to sit? Looks like you are right under that front beam.
SHSU
66Holiday924
SHSU
There's room to sit. Your head ends up right in front of the wood beam. I'll end up putting some sort of padding on the wood though.
66Holiday924
One of the design flaws with this boat, the reason the front cabin window was probably cracked in the first place, is the lack of support for the ceiling above the window. So, I decided to address that before I install the new window.
66Holiday924
Doghouse Build
With the winter coming I wanted to get the doghouse built to have an added layer of protection for the engine during the winter months. In the past I had it shrink-wrapped because there was no protection for the engine. This year I went with my store-bought cover, the doghouse and a tarp as an added layer.
I had enough leftover Coosa to do the whole thing in Coosa. The framing is kind of a hodgepodge. I used aluminum framing for two vertical members and the ones that are in direct contact with the deck. I used up some walnut 2x2's I had on the rear uprights, and the rest is untreated pine. The ventilation vents serve as the exits for my natural ventilation.
This is just the base structure. I plan to add storage to the top of it, maybe rod holders across the front. I was thinking about possibly keeping the portable fuel tank for the kicker motor on it. Any thoughts on that, anybody?
I used rivets and 316 SS Screws. I don't think I'd use the 316 screws again though. I'd try 304. The 316 are just too easy to strip out.
66Holiday924
The last thing I did before I closed it up for the winter, was to a add framing under the decking where my batteries will be located, run the fuel fill & ventilation lines and I found another chance to stuff some more floatation board in, so I took advantage. I have the board on-hand, plus I think it will give the boat both a more solid feel and make cut down on any rattling, making it quieter.
I'm keeping track of how much pink board I stuff in crevices, so I'll have an idea of what my floatation is later.
66Holiday924
Cleaning up the front cabin window frame, getting ready for the reinstall. I'd be lying if I said I was happy with it... The plexiglass is cut less than perfect. They didn't have much to go off. I think I can make it work though.
IslandExplorer
Looking great, keep cranking away on her and you're going to have an amazing end result here. I like that as you go you keep adding the flotation pieces into those otherwise useless voids. It all adds up to a much safer boat. Prob way less space for fumes or humid air below deck in addition to the quieter ride you mentioned. Lot of major issues solved and behind you. Looks like you're steady ahead for splash time! 🌊🤘
Good luck with the windshield work, thats always a bit of a challenge. Hopefully you can get that piece to work alright. Did they cut it a little too small? I think the brace you added will really help protect it from flexing too much and coming unsealed once you get it in there.
66Holiday924
yeah, they cut the plexiglass a little small in one area. Overall, I don't really care for how it's all fitting together, but looking at the original work, the way it came from the factory, this was always going to be an uphill battle. I'm going to use butyl tape and caulk and try to cheat my way through some of the shotty workmanship. Ultimately if it leaks, I'll cover it over completely from the inside with aluminum, and seal it, so the plexiglass exterior will be just cosmetic.
Today I started getting the bulkheads cleaned up. I'm going to attempt to install some Nautolex vinyl flooring, wire wheel and acetone worked pretty good. The yellow patches around my rivets is Gluv-It that I applied earlier in the build.
66Holiday924
I rough sanded, cleaned, and primed the cabin bulkheads. I used tractor paint on my other boat, and it worked out well, so I decided to go with oil-based machine paint again. It goes on nice and sticky, feels like it's getting a good bond. I wiped it down with acetone before I painted and brushed it on.
SHSU
Tractor paint worked well for me too. I used hardener too, but don't know if it was necessary.
SHSU
Watermann
I use the catalyst hardener with the Van Sickle paint and recently on a trip had the Chief moored for 5 days with no issues.
66Holiday924
The cabin window doesn't fit great. It's something I'll have to revisit later.
66Holiday924
This boat is my first attempt ever at doing boat interior.
SHSU
Looks good. I like your choice in vinyl!!! Admiral and I picked the same.
SHSU
IslandExplorer
Well, it sure isn't looking like your first try at it, coming out great! That little area is a real focal point when you first enter the cabin so that's going to make it look really clean and like factory new. Cant wait to see the end result with the cabin. 🍿
66Holiday924
Vinyl on the forward cabin bench. I guess they discontinued making Nautolex's glue. The Weldwood seems to be working fine.
66Holiday924
Building the lower deck
I used aluminum slats for support, and I had enough 3/4" Coosa leftover to piece in. For the flooring I'm using Big Box Brand garage flooring. My idea for using the garage flooring is ease of cleaning and replacement down the road. I'm not even gluing it in. The idea is to be able to replace it with ease down the road.
I installed three deck fittings. The forward access is to be able to get to the bolts holding the port-a-potty mounts. The drains are placed so that later there will be one in the cabin and outside the cabin.
I decided the side tackle boxes are all the storage I'm going to use as far as the benches go. I'll install floatation foam around them and the bench tops will be fixed in place.
Note: In some of my pictures you can see where the seams for the vinyl around the bulkhead of the lower deck area. I purposely put the seams there, because later the cabin bulkhead will conceal them.
