- Jul 23, 2011
- 53,297
A frosting bag and a plastic spoon makes good tools to make fillets
Who wouldda thunk, resin PB as a desert toppingA frosting bag and a plastic spoon makes good tools to make fillets
depends on how fast you can move and how big the bag is. I was able to do the entire bilge area in one shot. Maybe mix at 1.5%I assume that with the PB and frosting bag, I should mix it in small batches, as it will tend to harden-up as I go.
.That stuff looks familiar.
It is a gallon jug . . . should be enough, I can get more if needed. I also have milled fiber.Is that enough, Cabosil doesn't go far?
I've only seen it in large bags
When I did mine years ago it was about 80 degrees out and that stuff expanded like the movie the BLOB. I did it before laying down the deck and cut it flush with a hand saw. Worked out just fine.....still solid 18 years later.I foamed in the middle of that heatwave and left the pails in the shed where it was reading 120F. To say it kicked quick would be an understatement lol.
