[SPLASHED] I/O (Sterndrive) Conversion to Outboards
tpenfield
It was supposed to rain this AM, but the rain held off 'til PM . . .
I got some more pieces cut.
The extra 'stringers' are in line with the engine locations and notched for the splash well. I'm running short on the Coosa, but will see how much more is needed. I got a 1" thick sheet and a 1/2" thick sheet as well as a partial sheet left. We shall see how it goes . . .
harringtondav
Today I played trailer moving games . . . I want to see if I can get a decent balance point & manageable tongue weight.
The boat was about 6" off-center (to port) when we pulled the boat out of the water. So that was the first order of business. Once I got the boat lifted up in the air, I used my chain hoist to 'pull' the trailer to port . . . that was fun.
Then I 'very carefully' moved the trailer forward . . . about 20". So, I'll lower the boat and see what I have for tongue weight. As mentioned by several folks, I can always put some weight at the stern for transport to the re-power shop, then get rid of it once at the shop.
So the boat is 20" back of its normal position on the trailer. I just need to lower it and check the tongue weight. The trailer itself (no load from the boat) has a tongue weight of 350 lbs.
I just tuned in to this post. ....Nice project.
I haven't gone through all of the threads, so you probably explained this earlier:
This is going to move a lot of weight a long distance aft. What do you expect as far as floating waterline, planing, etc.
tpenfield
I was thinking about you the other day, good to 'see' you . .
Yes, Page 7 , post #130 . . .
I calculated the center of balance will move aft by 9 inches . . . the stern will be up by about 2 inches.
Total weight goes down by about 500 lbs.
harringtondav
I have no doubts that your weight calcs are spot on. ....previous experience with you on this still stings a bit. ;)
harringtondav
Another question: Will you fully enclose this to extend the hull to the end? ...also the new mini 'transom'?
tpenfield
The hull gets partially extended by 3.5 feet, it is not a full width extension. This is often called an extension pod.
Thinking about next steps . . .
Sort of like this . . . bolt holes shown 1 side for illustration purpose.
the aluminimum versions as made by Armstong use regular plastic deck hatch covers on top. usuall the 6-3/4" or 8", however some have used larger.
usually the ones with the big plastic screw so they dont have to deal with hardware. 1762781926519.png
tpenfield
I'm working inside the garage today, as there is off & on rain. The space is a bit cramped, but I'll make do.
As for the remaining large pieces, I have 5 more to go . . .
#1-3 will be 1/2" thick sheet and the #4 & 5 will be the 1" sheet. Then I got to double-up the #5 panel to get towards my planned transom thickness.
I may need a bit more foam board for stiffeners, spacers, the main transom structure mod, then some odds & ends. Not sure that I need the Coosa BW26 or just a regular foam core material. Trying not to spend a King's ransom on additional foam boards . . . any ideas or sources are welcome.
I checked my dimensions for symmetry, etc. . . everything is about +/- 0.1", better than I expected.
tpenfield
As for the foam boards . . . never mind . . . I got some good pricing on general purpose Divinycell (y)
Ted, one thing that popped in my head, the armstrong pods have a bilge pump
make sure you have some limber holes in the stringers / braces and a pad for a bilge pump.
tpenfield
Yes, absolutely . . . already in the plan.
Meanwhile . . . the waters are rising :LOL:
It looks like I won't be cutting any more big pieces today. :unsure:
tpenfield
The waters subsided and I was able to get the 2 'planing surface' pieces done.
They will stay loose for the time being, as I'll need access to the insides. Tomorrow should be the transom pieces.
tpenfield
why the cutout on the two inward pieces
Some ask why, I often ask why not . . . :LOL:
Gonna be sort of a splash well, but it is really to access the top mounting bolts of the engines and clearance for rigging (steering actuators)
Ted, are you going to build boxes on teh little wings for boarding ladders?
