redneck joe
Thread starter- Joined
- Mar 18, 2009
- 16,883
I would venture a guess that anyone on this list over 65 has at least one offset wrench that has been bent or cut and welded to be used as a distributor wrench. If you haven't seen it in a while it is probably sitting on a shelf behind that dusty dwell meter that you may never use again but remember how much you payed for it so can't bear to throw it away.Yep , I have a few spanners/ sockets that have been bent / cut / welded for jobs
Hey now I am 59 have bothI would venture a guess that anyone on this list over 65 has at least one offset wrench that has been bent or cut and welded to be used as a distributor wrench. If you haven't seen it in a while it is probably sitting on a shelf behind that dusty dwell meter that you may never use again but remember how much you payed for it so can't bear to throw it away.
Drove VW beetles back in the day. Nospecial distributor wrench required, but I do have a dwell and tach meter in the bottom drawer of the roll around.I would venture a guess that anyone on this list over 65 has at least one offset wrench that has been bent or cut and welded to be used as a distributor wrench. If you haven't seen it in a while it is probably sitting on a shelf behind that dusty dwell meter that you may never use again but remember how much you payed for it so can't bear to throw it away.
LOL ... I have the dwell meter (somewhere) for the boat before this one. Never needed the distributor wrench yet. And I'm 55!I would venture a guess that anyone on this list over 65 has at least one offset wrench that has been bent or cut and welded to be used as a distributor wrench. If you haven't seen it in a while it is probably sitting on a shelf behind that dusty dwell meter that you may never use again but remember how much you payed for it so can't bear to throw it away.
Here's my snap-on MT-460 just about a year ago when I installed new points in the dual-point in the Dart.can't find my distributor wrench....guess it's gone.
but here's my Actron!
Had a 1955 Plymouth in the early 60's. Last vehicle I owned with dual points.Here's my snap-on MT-460 just about a year ago when I installed new points in the dual-point in the Dart.
View attachment 413149View attachment 413150
That distributor is on the fritz again. Replaced the vacuum advance and leads this month. Put an HEI distributor in its place while I find the rest of the parts it needs.
